seat bolt question
Car: 83 Camaro
Transmission: th350
seat bolt question
ok i was taking out my thirdgen seats...and the stud broke that the nut goes on for the drivers seat.....do you think it would be ok if i just drilled a hole through and put a bolt and washer through the bottom
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
are u talking about through the floor pan? im sure u can but make sure u seal it with caulk or something, if i were u id just use 3 bolts instead of 4...my car now has only 3 cause i have momentarly lost one of the nuts..seems fine, still firm and tight
Car: '86 Trans Am
Do not drill through, just use three. I only have two on the passenger side of my car and it holds the seat like the drivers side(which has all four).
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
3 is great until you get into an accident and you break your back because the seat twisted. Find somebody to weld a new stud in. If you take the carpet out yourself, it shouldn't cost much.
84z96L31vortec
08-20-2017 12:16 AM
1992 Trans Am
08-08-2015 08:16 PM
