4th gen seats in a 3rd gen
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
i did a search and cant find anything i need to know. i am curious to know how hard is it to install 4th gen seats and what other hardware to i need to do it, also, if anyone has any pics of their swap i would like to see it, thanks
You have got to be kidding me right? Not to be harsh or anything, you obviously didn't do a search cuz this topic has been covered literally thousands if times.
Im not trying to be a hard ***.
To answer your question, YES, they will fit with no prob, they will bolt right in. The only prob you may have is if the 4th gen seats are power, and yours arent, and you want to take advantage of it.
Next time try and use the search feature a little better.
![Roll Eyes (Sarcastic)](https://www.thirdgen.org/forums/images/smilies/rolleyes.gif)
1 Post
sorry, i didnt get the answer of they bolt right up, i didnt feel like reading every past post on the subject
Don't feel too bad, I was wondering the same thing after reading his first post so I hit the search button and tried some things.
First I ran a search for "do 4th gen seats bolt up" and got 11 results back:
https://www.thirdgen.org/techbb2/sea...der=descending
Then I ran a search for "do 4th gen seats bolt in" and got the same 11 results.
So I just tried "4th gen seats" and got 85 results back.
How about "4th generation seats"? 26 back.
Anybody wanna help me here? I can't find a string that DOESN'T come up with at least one or two or 3 results that answer the question.
Oh, here's one. "I wear pink slippers in public showers" doesn't seem to return any 4th gen seat info.
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
Car: 1987 Iroc Z "Classic Roc"
Engine: 5.7 350
Here ya go Chuckles! I have a set of '95 Camaro seats in my '87 Iroc. Bolt patern is exactly the same front and back. I actually took out the rears last weekend. Took all of 2 minutes.
(cut and paste the link)
www.geocities.com/jamie_caruvana
1 Post
Car: 00 TA, 91 Formula, 89 RS
:sillylol: :sillylol: :sillylol:
Yes, they are a perfect fit.
Dont worry, I wont lock or delete this post..............yet.
1 Post
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Hey hes just tryin to find info dont give him a hard tim. But yea I put some grey leather from a 99 maro in my RS a couple weeks ago, and it was easy as hell, worst problem was getting the rear seat belt holders out cause they had some thread lock or somethin on them. I even changed the tracks on mine, cause i didnt want power drivers seat cause it sat up to high, and everything just bolts right in place. Its basically 12 bolts and 8 screws for the seat belt holsters. If you can wash it you shouldnt have a problem. Dont have any pics of mine yet, but they look real tight and there a hell of alot more comfortable and sporty feeling...all i need now is some rims and an Ls1/T56 combo ..someone give me money..
1 Post
Car: '89 RS Convertible
Engine: 355
91Camaro....check the pics of my car. The URL is in my sig. Just cut and paste it into your browser. And if you're not sure how to do that...you might wanna do a search on that topic
![Stick Out Tongue](https://www.thirdgen.org/forums/images/smilies/tongue.gif)
Originally posted by DJP87Z28
Well I used a 14mm open end wench and 14mm socket on mine and they were a perfect fit. Go figure??
I'm not even aware of a nut out there that has the proper metric thread with a 14mm head instead of 13, but I suppose they could exist.
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
im probably not in any other previous topics so for anyones information I have a set of 99 firebird seats in my 87 Iroc. They kick a$$. You can see em at my www page.
I just put in 4th gen seats and seat belts yesterday! it was not hard at all... AT ALL! just took some time about 5 hours... the seats proby take an hour or 2 to swap... check'em out! the link is in my sig...
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
Originally posted by bubbakutz
my seats are not power.....if i were to pick up a set of 4th gens that were power then what would i do? hook them up to power if its possible.....or if not how do they manually move....is there a lever on them too like manual ones?
1 Post
Engine: 355
1 Post
Car: 92 Z28
Most 4th gens have power drivers, especially leather. I got mine and decided I didnt wanna sit up that high, so I just changed the tracks. Also the 4th gens dont have the little plastic covers over where the bolt to the floor..you could probably drill holes and put them on but it's really easy to change the tracks, just disconnect the springs and move the tracks so you can get to the front nut and the the rear nut. Good luck
