Outer door window felt replacement.
I was looking at the outer window felt the other day and was wondering if anyone has replaced it with the window in? There are 2 bolts that are still behind the glass with the window down. Any advice on this?
RMK
RMK
Car: 1986 IROC-Z
Engine: 5.0 TPI
I assume you have the door panel off. What I did was loosen the 2 bolts on the brackets that hold the window towards the outside of the door. Then you should be able to pull the glass back far enough to get them out.
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
