M3 Mirrors revisited...
I'm not sure I like it.
Finally got around to making an "adapter" to make the mirror sit more horizontal and level with the plane of the car.
Here's a comparo shot of both mirrors from the front:
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
It's different, but not necesasarily in a bad way. I think it could be a little closer to the car on the top of the mount, but overall it's interesting. Nice work btw!
I forgot, are you planning on having the lights function?
Car: '99 Ranger (Need 3G)
Engine: 2.5L
Transmission: AOD
Wow.... I'm likin those mirrors! Looks great to me! Hopefully it'll grow on you, its your car, you gotta like your mirrors! Good luck with em... they look awesome!
Car: 88 GTA
Engine: 5.0
Transmission: Manual
Axle/Gears: 3.45
i kinda like it- very nice work-
p.s. is there something wrong with your hood? in your first pic its kinda crooked
Originally posted by Jim85IROC
I'm not feeling it either. It just doesn't seem to match the flow of the angular body.
Thanks 88CamaroKid and 6cycbird86 - I appreciate it - and the hood isn't shut or locked down. However, the nose on my car has sagged a bit, so even when it IS shut and locked, there is still a gap there.
Originally posted by MetalliCamaroRS
Ehhh I don't think I like them either, but they're not too bad.
S.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It doesn't look bad but, it seems to have too much 'rotation' the wrong direction (pic). It makes it seem to not match the lines as well as it could.
Cool idea, theres just something that doesnt fit with the base of the mirror (where it connects to the car). In your 2nd and 4th picture, you can see that the base is kind of at a completely different angle from the side of the car... I dunno if thats the mirror or the mount you said you had to make to make it fit. It just seems out of place... Any way that base could come off and have just the mirror on the two arms?
(just a thought)
EDIT: looking back at the pics, if you cut the base off that top arm would be WAY too short. Youd prolly have to extend it, like you did on your spoiler. I dunno how goofy it would look with that long arm on it either....
(just a thought)
1 Post
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Hmmm... its interesting. I could tell better in person...
Speaking of getting just the right angles... I got way lucky with the 4th gen bird mirrors. Gm managed to keep the angles close enough. Though it took a ton of channeling. Do you have any direct above or below shots. How about some from the drivers seat? Just trying to get a real feel for the mirrors.
(just a thought)
(just a thought)
Originally posted by Dan88IrocZ
I like it now, but I'd like it even more if the whole assembly was...bigger?:hail:
Like a tumor.
S.
1 Post
Originally posted by N.W. T/A
Radraif... Did you ever finish off your 4th gen mirror swap(interior part) I liked the look so much I bought a pair.
I know you do a lot of fabbing yourself, so as much as it may be a PITA, (and it could still look like ***), you could always do away with the arms, and use welded steel (very thin stock) to MAKE new arms, then glass around them to smooth them out...
Just a thought
I love the idea of those lights on our cars though. Good stuff, keep shootin at it, it looks way closer than your first attempt from a few months ago.
Just a thought
I'm thinking of doing this to the point to see if it flows with the lines of the car in a more angular fashion...
Any further comments?
admrlam: If I get to the point where I'm still not sure about it, I may go that route. Shouldn't be too difficult (comparatively speaking) but as I noted earlier, that'll destroy the mirrors completely if I don't like them after doing that. Who knows; but I'll keep y'all posted.
S.
S.
I dunno - what's going on? Or is that just the opening night?
BTW - Do you happen to know anyone that does speedometer "calibration" readings? I need one pretty bad for a speeding ticket...
S.
S.
I don't like it , the shape of the mirror is just not fitting with the rest of the car at all.
I would prefer to see the blinkers implemented into a 3rdgen mirror housing.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
S.
S.
My friend with a 99 SS got out of a 100 in a 55 a couple of months ago, I'll ask him where he went. He has a speedo calibration box with 2 settings for the LS1 for rear gear swaps and I had it programmed for normal speed and 50% speed to keep the miles down. He took it to the shop set at 50% and got a receipt saying it was off and then went back the next day with it set to 100% and got a receipt showing it was fixed. $57 fine for faulty equipment.
I would forget about the mirrors and rob the signals out of them and try and make them work on stock 3rd gen mirrors or something that fits better. Those just don't look right unless you re-locate the signals completely so that they are straight from a side view.
Car: too many ...
I like it. I've been thinking about mounting a mirror there for a long time. Not sure if that rubber piece will be able to hold it up at speed. I was thinking about making metal support pieces front and back.
1 Post
Well I have the 4th gen mirors attached there and have driven it on the hwy quite a bit...at times at 85-90...no safe place to really open it up. The triangles have heald up great. No flexing at all. And I even had to channel them out to fit teh 4th gen mirrors. a metal braket would make it even more secure, but I'm not sure you really need it!
Car: 87 WS6 T/A
Engine: 97 LT1
Redraif: I was looking at how far the window rolled up into the triangle piece and it looks really close. Please set my mind at ease...........thanks
1 Post
Then I tset fitted the mirror to see how it fit and how I wanted it...Then w/o that metal mounting bracket in the way I traded the mirrors mounting surface on cardboard. Then I reinstalled the mounting bracket and slowly maked its placement and trimming till it fit tthru the carboard. It made a perfect pattern of the mounting point and plate of the mirror.
With this I went to the car and placed the pattern where I planned to mount the mirror. I first drilled the bolt holes!
You can see it is close to the weather strip where the window travels, but not close enough to cause a problem...
1 Post
Then with the mounting bracket installed on the mirror I test fit it to the car. I slowly removed material and retest fitted the mirror till I got the mirror to sit flush...
Here is the finished product...you can see the channels... I never had to got thru the triangle pices except for the inital bolt holes. There is still plenty of material where the channel is to keep the triangle piece strong!
1 Post
backside with the mirrors on and window up. You can see where I need to clearance the inner window sill...
Car: 87 WS6 T/A
Engine: 97 LT1
Looking at my 87 T/A I dont have the weather stripping like on your window, just the hard plastic piece. I think I might scrap this mod. Wanna buy some 4th gen mirrors :-)
Pac J
05-17-2020 10:44 AM
tglennon11
Interior Parts Wanted
09-11-2015 10:25 PM
