weak air flow on a/c, heat, etc.
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
as it says, i've got a weak airflow whenever the a/c, defrost, etc. is on, even on high. the fan seems to respond to the fan control switch, all speeds work, but air flow just ain't there - very weak. i don't hear any vacuum leaks, so where do i start? i've replaced the fan motor a couple of times over the years i've had the car (10), last one was changed probably in '98 or '99...
KAM
KAM
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
theres a rubber gasket type thing around the blower motor, make sure air isnt leaking around it
Car: '91 Z28
Axle/Gears: 323's
i was reading another post on this subject in another forum and it was mentioned about the relay... wonder if'n that could be it and/or have anything to do with it. i just don't see where a fan could wear out so soon. when i replaced my heater core a couple of months ago, i checked for blockage then, didn't see anything. or maybe one of those vacuum operated ports aren't opening...?
KAM
KAM
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It's not the fan speed that's the problem. It's actually just because the HVAC systems in these cars suck.
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Yeah, I recently replaced the AC blower in my car because the fan was so weak. It helped a little bit, but it blows no where near the CFM of newer cars. I can still barely feel it in my face if I have the vents positioned to blow at my face.
The A/C systems just suck.
Transmission: autos
is there cabin air filter on our cars, if so where is it? my hvac system is good, afer i fixed the leak around the blower...blows really good...maybe yalls cars suck..naw jk
Car: '91 Z28
Axle/Gears: 323's
never heard of any filter on these (or any other) car, but it was mentioned one other time about possible blockage from leaves, etc. when i changed my heater core i checked all up in that area for debris and what-not, but it was clear, so i'm thinking something isn't opening all the way or the blower just sucks on power
KAM
KAM
eightsixseven
08-14-2015 03:09 PM
