MPH Gauge Not Working
Car: 92 Chevrolet Camaro RS
Engine: 305 TBI
Transmission: Stock
I have a problem with my MPH gauge, All of my other gauges work but the MPH one does not.
Afterm driving for a while the check engine light comes on and then after about 5 minutes it goes off and the MPH gauge starts working.
It is almost like it needs to hear up first?
I have already replaced the cluster and the same thing is happening.
Does anyone know how to fix this?
Engine: 305 TBI
Transmission: Stock
Originally posted by MikeZ28
i would check your vss its most likely the culprit...does your odometer work?
Just not the speedometer
Engine: 305 TBI
Transmission: Stock
Looks like the odometer is not working after all,
This is starting to be a real problem.
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
humm i have that problem too. Do u still have a plastic push button for the tripometer? Push it in a few times, hear like a gear noise? Now drive the car. Speedo should work. If the piece is broken us a paper clip, toothpick or what ever. Im not sure why mine does that, even didnt work after i replaced the cluster. Shoulds like the same deal on both our cars, espically since they are so close in age.
Engine: 305 TBI
Transmission: Stock
Seems like my issue is the same as yours,
I have put in 2 different gauge clusters and still have the problem.
I think it might be the sending unit that makes the gauges work
Car: Pair of 92 Z28s
Ok what about just the speedometer cable altogether? Could it have got damaged somehow..i dont no just an idea
Only reason im saying this is because i just learned to replace a speedomoter cable and did it today...but that was because my speedomoter needle keep bouncing all over the place and making wierd nosies but i im not sure if just changing it would fix ur problem
Engine: 305 TBI
Transmission: Stock
Seems like that is the next step for me,
I just don't know how to change it because I have never dont it before.
Any help?
:lala:
Any help?
:lala:
Transmission: autos
your 92 doesnt have a speedo cable. When u drive with the heat off windows up radio off, can u hear a noise from the speedo, like a clicking?
Engine: 305 TBI
Transmission: Stock
I use to,
I think it has stopped but it use to make a kind of a grinding or clicking noise kinda like gears rotating
Transmission: autos
yup it only does it when the speedo works. try what i said about the tripometer, its a good temp fix, or permant, i have to mess with mine maybe once every 2 weeks
Ghettobird52
07-05-2024 11:18 PM
