For underbody: Paint, POR15 or rubberized coating?
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
My underbody is rusted and before it gets so bad that It looses integrety I would like to repair it.
I have a pneumatic dye grinder and I was going to use a wire wheel to remove all the rust. What would be best to coat it after that?
The car is no longer driven in the snow. Rarely in the rain.
Thanks,
Chris
Thanks,
Chris
por15 is great stuff
brushes on easy and doesn't even leave brush strokes. you just really have to clean the underbody which could be a major chore.
my vote goes to por15
Car: 85 Camaro SC
Engine: V6
I second the notion for the por 15. I would use the wire wheel on the entire bottom and coat it as well. Kill two birds with one stone.
I thought for POR-15 all you had to do was remove loose rust and then just paint it, Paint Over Rust....POR...see...i dunno if that is what it stands for. But that was my guess.
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
is this stuff only available on the 'net? or do any parts places stock it?
just wondering....i think i may take the plunge and do a LOT of my undercarriage with it.
-Brian
-Brian
1 Post
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
i you dont want to spend the money on the por 15, i did my engine bay not to long ago with the rustoleum oil based paint that came in a gallon for 15 bucks. i did 2 layers and it is thick. i tried scratching the stuff a week later and it took a good amount of force to scratch it off. i heard the por 15way is rock hard. but i figured if a rock flew into there with as much force as i can push then i will worry.
Car: 91 Camaro RS
Engine: L03 for now......
Transmission: 700R4 for now.......
spartyon
I was thinkin about doin the same thing. i found some decent looking rustoleum paint(matches the car's scheme well) and i was thinking of using it over por 15. still havent decided. am i gonna be missin out a lot if isay cover the bottom in paintable coating and then spray paint it? thanks for the info guys.
Car: 1987 Black IROC-Z (SOLD)
I have used and like POR-15. But in my opinion it will be a b----h
to cover large areas with a brush with the three steps that are required. Small areas are OK...
Car: 92' RS
Engine: LO3
I will most likely do it in stages. One area for when I take the trans out . Another part when I take the rear out. I already bought the POR-15, I was just having second thoughts. But you guys have eased my mind.
Hotrodboba400
12-10-2019 07:07 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
09-06-2015 06:23 AM
