Everyone with a GTAuto RamAir II hood>>
How in the heck did you get it to fit. I was one of the first one's to purchase from him a few years ago, and he seems to be no help. I have about a 1/2-3/4" gap up front. I'v tried realigning everything, even headlights, but nothing seems to work. It seems to be hitting my radiator support, do you guys think it would be ok to trim it underneath, and hopefully that'll fix it, but I don't want to weaken the hood at all....
here's a pic
It's been like this for over 2 years now...IT'S TIME TO FIX IT!!!!:hail:
here's a pic
![](http://tiger.towson.edu/~wchalk1/cgcbandit.jpg)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
wow that is a big gap.
you think its caused by the spring at all? also did you try to move the latch down?
how can you tell its hitting the rad. support.. did you try and take off the rad. support to see if it goes down at all?
The latch is as far down as it can go, I also cut 2 coils off the spring(which now makes it a pita to open). I can tell it's rubbing because of the yellow paint marks on my support.
Car: Trans am
i'm sorry to say that its just your hood. look how the side are perfect but the front is up , the front is just that bad, i got one a few months ago and just got it back march 7th and mine isnt perfect but its not that bad.
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
I have heard quite a few complaints on the quality if GTAuto's hoods. Not many people seem to have it line up right. I know the same is for teh quality on the US Body Source's hood too. Mine never lined up quite right, it took a little bit of fabbing.
Nope, it's never been in an accident. I knew the previous owners very well, and a clean Carfax at work. Thank everybody..looks like there aint chit I can do
![Mad](https://www.thirdgen.org/forums/images/smilies/mad.gif)
1 Post
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
You can trim the hood without weakening it too much, but the problem is that the fiberglass is probably set in that position by now... even if you make the clearance, itll probably stay like that. Just another reason why I didnt buy anything from GTAuto... I have yet to see 1 hood fit perfectly. ASCD will be getting my buisness. Ive seen their product, and its worth every penny.
Bandit,
I have the same problem you have with the hood, i think he hadn't quite perfected the hood on that first batch that we bought in on. I haven't managed to fit the gap but i do have some ideas on it. I think by putting some washers or something else to raise the hood in the back(near the windshield) this will bring the front down closer to being in line. My other thought is to bring the headlights forward a bit to close the horizantal gap, moving the headlights is something i need to do anyway since my driver side headlight is not aligned correctly, whether that is a factory thing or the previous owner had an accident i don't know. feel free to email me if you want to discuss some other ideas.
Car: 1992 Camaro
Transmission: auto
Hello Guys i think it is a mold problem i have had moldspast I have learned from my mistakes and try to do better now. Rex Orr
My USBODY hood is a bit like that - though a lot of my gap comes from the front bumper cover/nose cone "sagging". It's like the cover has drooped along the drivers side which gives the front gap; the gap along next to the driver's side headlight is just because of a bad/imperfect mold. I've heard you can heat up fiberglass and bend it to a new position but I'm going to ask a boat/fiberglass shop before I attempt it. Actually, I'll probably have the guys who do that stuff for a living do it.
S.
S.
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
Car: 1991 GTA
Transmission: AUTOMATIC
HOOD
Originally posted by CGCBandit
So is there anything I can do to it...besides buying another on
Looks like he never responded.
Car: 1992 Camaro
Transmission: auto
hood problem
Hello will trimming the front turned down lip help lower the hood ? and also a adjustment on the hood latch that is on you car adjust it down. hope that is some help. sincerely, rex orr
soulbounder
09-05-2001 09:46 AM
