91 z28 high rise spoiler fitting on a 91 firebird
Im getting the 91 high rise for my bird.... i just want to know if it will bolt right in place or if i have to drill holes.... (please tell me it will fit in place)
Plus a great help is if anyone has pics.... before/after/durning.. it would all be great thanks.
Car: 1987 Trans Am
You'll have to drill holes, unless you're getting the decklid with it. If the new spoiler doesn't cover your existing holes, you'll either have to weld them shut or switch to a non-drilled decklid and just drill the new holes in it.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Originally posted by LT1guy
Do a search on Zephyr, he had one on his car too for a while.
Originally posted by panman79
Wow, you're the guy with the wicked bad cam on that video I saw.Your car smokes man, I like the way that cam sounds!
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Originally posted by Firebird 383
I believe deadbird has a Firebird with a Z28 hi-rise spoiler on it.
What are the specs on that cam? How bad are you guzzeling gas now? Your polish job on the tpi setup doesn't look too bad either.
Thanks for the inspiration
I am not gullzing any gas at the moment since there is no motor in the car. and LT1 is going in very soon. 350rwhp N/A and 500rwhp in the Nitrous.
Car: 1990 Pontiac Firebird
Engine: V8,350,5.7 L.
Transmission: Automatic - 700r4
Re: 91 z28 high rise spoiler fitting on a 91 firebird
Does the wing fit on the trunk?? I am about to do the same thing and it just looks like there isn't enough space to bolt it down.
Engine: TPI 305/ v6
It bolts to the decklid and hangs over the quarter
panels.
Resurrecting a post, via searching, with a good question
panels.
Thanks for the info(: I'll post pics when I get mine done.
colton_carlson
03-08-2019 12:21 PM
