83 t-tops conversion
Can anyone tell me if you can convert the hook style t-tops on an 83 to the pin style of an 84 and up. Has anyone done this? If so...how? I would appreciate the help. Thanks in advance.
Car: 1987 Trans Am
The seals are the same:
http://www.hawksthirdgenparts.com/weatherstripping
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
I will be checking today to see if the pin mounting hardware can go on and what it does to the angles!
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Yep...just gotta swap over the plastic receivers on the body to the pin style ones...then trial and error to adjust them to seal properly.
I installed the tops out of an 86 'bird into my 83 SC, because the 86 ones have locks....
Pete
Pete
Yep I checked it out Saturday and it has the smae mounting points. I'm gonna switch it out.
Thanks for letting us know it worked Pete!
Thirdgen89GTA
11-27-2015 12:04 AM
