Removing the protective exterior molding?
Car: 94 s10, 97 s10
Engine: 383cid, 350cid
Transmission: 4L60, NV3500
Axle/Gears: 3.73, 4.10
I've seen a lot of thirdgens without the molding along the side that protects the car from door dings, shopping carts etc. Is this something that's easy to remove? What holds it on? I really like how they look without this.
Transmission: A4
They are held onby double sided tape. They come real easy by getting behind it and then just puling it off. The only bad part is that you may also pull the paint off as well.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The old style that used trim rails and rubber inserts were riveted on. The newer style (wider/one solid piece) is held on with double faced tape.
Transmission: A4
it should be the newer thicker style and should just peel off. There will be left over sticky crap lefton the car, Use a cleaner that wont eat or soften the clear coat as you rub it out . if you just use your fingers to rub it off, you WILL get blisters. been there before
i have the rivit on style. i actually like how they look. at first i dodnt like how they looked but it grew on me. i like having them until i move out of my parents house , what i mean is right now its my second car and i drive it to work when its nice but when i move out it will just be a show car so i will remover them .
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
my 87 never had moldings on it.....so that means.....20 door dings on each side......so when i got it painted had them fix up them there dings and im not putting any molding on it.....looks smoother and cleaner to me
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i plan on gettin those door garde things for my car i got 2 dings in my driver door 1 week after i got it repainted and there just small enuff to be covered by them but ill just fix them becuz i have a spot where someone nailed the door and cracked the bondo/fiberglass filler.
u can just barrely tell theres dents there but there all along the part where the guard thingy would be.
IROCZDAVE (88-L98)
Exterior Parts for Sale
09-06-2015 07:23 AM
