Best way to repair floor panel is?
A couple floor pans are rusted right through on my 83Z. One hole is about the size of a softball. The other, the size of a tennis ball. What is the best way to fix? Take it to a body shop for a whole new panel? Or can I (garage mechanic) do anything? Or should I just use this car for parts to fix up my Iron Duke Camaro?
Thanks,
Brandon
Thanks,
Brandon
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
if u have a welder, or a friend with a welder, u can weld in some metal for a patch, i got a friend that did that on his and it seem to be fine...if u dont have access to a welder, u can bolt metal over the spot,t wont seal as well or look as good, ull see the bum in the carpet from the head of the bolt...but it sounds ver repairable
Thanks guys for your replies. Looks like I'll need to trash her. Found some more rust holes. This time through the tranny hump. I think she's too far gone for salvage.
Brandon
Brandon
Car: 85 Camaro SC
Engine: V6
Find a junkyard that has a car with good floor pans. Cut them out and cut your pans in the same place making sure to cut out any rust in the pans and cut a patch out of the junk yard pans to just overlap the hole in the cars pans.
Transmission: autos
u can also use sheet metal u can buy at some home improvement stores and patch it up, it doesnt sound to bad,though i may be under estimating it....also NEVER use J.B. Weld..there is nothing on earth cheaper, id use 2 part poxey before jd weld
Car: 91 RS
Transmission: TH 700 R4
J.B. Weld IS a 2 part epoxy, I have used it to repair gas tanks that had rust holes in them and they never leaked again, that **** hardends to like steel dude.... for small holes you can't beet it but for big holes you should pop rivet in some sheet metal, cut the sheets bout an inch bigger than the hole and put some urethene caulking to 'glue' it on to stop leaks then drill holes through both floor and sheet metal you put on and pop rivet it.
Transmission: autos
i use Metal+Metal 2 part apoxey it works better than jd weld, the jd weld held my crack in my raditor for about 20 miles and leaked it all out
All this could be repaired. But...floor pans mostly made up of patches? As far as the junkyard idea...I don't have the means to cut or weld. Body shop would need to perform all this. I have a 1984 Iron Duke Camaro (Texas car...NO RUST!!) Thinking about swapping the dash, etc as well as the V-8 parts including the engine/tranny later on this year into a better bodied car. All the rust can be fixed....there are other issues as well. Such as no emissions equipment, which is a must where I live. Doors also need replacement. Or maybe I can park it till $ for the new pans can be had. Junking her sounds like the best idea.
Brandon
Brandon
Let me ask a question...would YOU junk a car for rusted doors/floor pans? Or would you obtain new/used floor pans and take to body shop for install? The car is nothing really special to me. I like the fact that I own a Z28. But all of this plus the emissions deal + the car leaks like a mother. Would you save this?
Brandon
Brandon
Car: 91 RS
![Cool](https://www.thirdgen.org/forums/images/smilies/cool.gif)
Update: Cut up some carpet in the Z yesterday. The floor where the driver put there feet is pretty much rotted away. We're talking about from the door to the tranny hump and from near the pedals to just in front of the seat. Some metal is still there. Even the frame is exposed near the tranny hump. The rest of the holes in the car are some good patch jobs. But this one...probably can just cut some flooring out of the parts car I have. Opinions? Is this car still salvagable? BTW, one good stomp on the floor and the rest of the metal will fall away on the road.
Brandon
Brandon
Here's a pic I found of someone else's floor pan. If you chip a way all the rusted areas, this whole is what you get. That whited out portion represents the frame. That circle in the frame is part of frame exposed. Does this look like a professional job or can I do it myself? Actually that whole will extend to the frame. So the whole is bigger than in the pic.
Thanks,
Brandon
Thanks,
Brandon
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1985 Camaro
Engine: 5.7, Vortec heads, Headers, TBI
Transmission: Built 700R4
Axle/Gears: 3.23 BW 9-Bolt Disc Brake
im not sure where i saw this but they are now starting to make new weld in floorpannels for 3rd gens two pieces i think a left and a right. Ive parted out a wrecked camaro before and i regret it every day because it could have probably been fixed but i didnt so try and fix it we need all the 3rd gens on the road as we can keep
I seriously wanna fix her. I love this car! But to spend a few thousand installing new floor pans??? Thought about cutting what I need to fix this outta my spare car, since it's not worth anything.
Brandon
Brandon
Car: 85 Camaro SC
Engine: V6
Heres what I would cut out, its much cheaper to go to a junk yard and retrieve a used rustless floorpan. Find someone or even the junkyard should have a cutting torch to cut out what you need. Cut off a little extra so you can have something to work with.
Looks like she's nothing more than a good parts car for my SC :rockon:. Found more rust all up this sidewall in the yellow circle.
Brandon
Brandon
Car: 1988 IROC
Engine: rebuilt 350
Transmission: 5-speed
Where did you get the idea it would cost a few thousand to fix floor pans? GO to www.Shermanparts.com, they have new floor pans for third gens starting for about 200.00 each side. Take the new pans to a body shop and pay about another 200.00 having them put in. It may cost close to a thousand, but you would have full new floor pans.
Brandon
Originally posted by 84 Challenge
A few folks said the price tag would be a few thousand. OK...found some new floor pans. But...what about that kick panel????? It's rusted away at the seam going up about 6 inches. Can that be repaired as well?
Brandon
Brandon
My car's floorpan was rusted all along the rocker panel and under the drivers feet and in the backseat footwells. I couldn't afford to get it fixed properly (and can't justify spending over $1k on a car thats only worth a few grand) so I patched it myself.
I figured out where all the rust was by poking at it hard with a screwdriver, then I cut out all this area with a cutoff blade on a cheap angle grinder. I then painted all the remaining metal with Por-15 and painted some scrap metal with Por-15. I cut patch panels and trimmed and bent them to fit. It took numerous patches to complete the floor. I overlapped all the seems and used silicon caulk sandwiched between the seems. I used many rivots (about every inch or two - some put in from the top, some from the bottom) and a bunch of self-tapping sheet metal screws. When done I again painted the floor with Por-15 on both the inside and outside.
I did this a year ago and it has held up fine. The floor is rock solid and I hope it will last for years. HOWEVER, the repair looks like total crap and this kind of repair could never be done to a car that would see a car show. Look under the car and its obvious that patches were rivoted in. Pull the carpet up and its obvious that it wasn't repaired correctly. BUT the floor is solid and safe and the rust has been greatly slowed or stopped. The rest of the car is in pretty decent shape but this car is a 3.1V6 and will never really be worth a whole lot. If the car ever get restored I'm sure the whole floor pan will be replaced with new metal. For now this has been a solution that completely met my needs and was cheap.
Good luck.
Good luck.
I didn't have a welder or I probably would have tried welding up the patches. This, however, would require much more accurate patches to be fabricated.
Getting big chunks of a floorpan from a donor car would make everything much easier. I, however, couldn't find a good floorpan in a junkyard close to me and I already had some sheetmetal so it didn't cost me anything.
It took me at least 16 hours to do the drivers side and about 8 hours to do the passengers side so it was no small project. (But it hardly cost me anything in dollars.)
Good luck.
Good luck.
Brandon
84 Challenge - Those floor pan pics are from my car..... Perhaps I can provide you more information.... Obviously, you already saw and read the info I have on this page:
http://crzyz28.sytes.net/floor.html
I did not bother to read this entire thread, as I was not sure where you really stood with this project.
I can tell you this, replacing the entire floor pan is a HUGE mess. Mine (as you see from the pics) was REALLY bad. If you have some small holes, there may be other avenues.
If you have to replace the pan, it is almost impossible to make a clean pull of a car from a junk yard. The pans on those are probably as bad, and is not, the the remove of them is next to impossible without bending, disfiguring and requiring some patching to finish. You might as well save time and trouble and buy replacement pans from Classic Industries.
In anycase, if you need some input, ,y skills are limitted, but I know a thing or two from this project.... And when my father, his neighbor and I ripped into it, we had NO idea what to really expect....
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
![doh](https://www.thirdgen.org/forums/images/smilies/doh.gif)
Brandon
This will not be a show car. BTW, I don't have access to a welder. That's why the patch idea came to mind.
Anycase, as far as your problem goes. My Camaro at MOST is worth $1,500.... I put $1,500 into to repair a quarter panel (I wrapped it around a telephone pole years ago).... And then I have done other projects (including the floor pans). I don't remember, but I think with NEW pans, carpet and materials, my floor pan project was about $500-$700 (and that was a group effort of me, my father and his neighbor in his garage with a welder). Without a welder, you increase your dificulty and possibly decrease the success of the end result....
I did read how someone on this board did his with pop-rivets. If you're looking at the work I had... Eh, you could do rivets, but I don't think it would be as solid (and solid is what you want). And I don't think you can cut the pan and tow it to a shop to be welded (as the pan REPLACES a true front to back frame and in the tow you would probably twist the body). Also, my pans were done 1 side at a time (to preserve the structure of the car).
No matter what, you're looking at a lot of work and probably a similiar $500-$700 price tag (you can shave some money off that if you don't replace the carpet). The effort involved in a full replacement is NOT worth it unless you intend to restore the car to keep for yourself (regardless of show quality). Ex. I intend to keep my Z28, and I intend to make it 100% beautiful inside and out and as best as possible on the underside of the body, but I know it will NEVER truely be a show car.....
Sorry if that's vague, it's more my 2 cents then anything.....
I appreciate your comments...Maniac! Still not sure what route will be taken. Definitely would like to save this car but I don't know. You'd probably say "Holy Crap!", if you came out here to look at the damage. Still have quite a bit to do: new weatherstripping for t-tops, emissions equipment re-installed, new doors, new fender, new carpet, headliner, exhaust, e-brake cables, intake manifold, carb............................................... Love this car, but JEEZ! BTW, dont' really have a place to store car while parting out either.
Brandon
Brandon
I feel your pain.... I've already restored most of the interior... Really could not do what needs done on the exterior due to lack of area to perform that kind of work... Will, now I bought a house with a 2 car garage.... I want to pull mine all apart and I'm looking at:
- Fender removal - possibly replacement
- Minor rust clean up (on the out side of the car)
- Big time strut tower repairs
- Full Engine overhaul
- All new sensor wiring (dry rot and corosion SUCKS)
- New weather stripping
And that's the TIP of the ice berg for mine.... The bright side, all the imperfections I don't like are hard to impossible to see in the pics I have of my Camaro![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
So do I think you're crazy.... NO! People thought I was crazy to repair my Z after I wrapped it around a telephone pole, but I did.... People thought I was crazy to repair/replace the floor pans, but I did.... And some people think I'm crazy for spending more money in my Z, but I will.....
Car: '87+'02 Z28
Engine: 454 LSX
Transmission: T-56, Viper output shaft
Axle/Gears: Strage 12-bolt 3.73:1
I actually am repairing my floor pans and I had a new piece of sheet metal welded in on the drivers side from under the dash to the front of the drivers seat. The guy did an excellent job! He even shaped the metal to match the original and then coated it with a rust inhibitor. He only charged me $200 for that and fixing another hole the size of a softball.
I also have several small holes which I am patching up with wire mesh (made by Bondo) and JB WELD. So far it is working very well. I have to sand down the drain areas and then I am ready to paint. Just thought I would share this info.
Maniac....Do I think you're crazy for spending more $ on your Z....YES!!! j/k
. I guess you get what you pay for when only a grand is paid for a 1983 Z. It's actually a nice car for $1,000. My wife will be tough one to convince, regarding the Z.
Neil....guess there's all kinds of way to fix floor pans. Just how strong is JB Weld? Wait a minute, you're from Houston! Why are you messing with your floor pans????
Brandon
![Frown](https://www.thirdgen.org/forums/images/smilies/frown.gif)
Brandon
The bottom line is to be happy with your decision and to each there own.
At this point, I will butt out for a while (the current end of this thread is way to full with my opinion crap)....
But if you need info from me, I'll try and help as best I can....
Car: '87+'02 Z28
Engine: 454 LSX
Well Brandon, I am originally from Ontario, Canada, and the car was never really winter driven but it saw it's share of salty roads! I moved to Houston in '96 and I now decided it was time to clean her up.
Car: '87+'02 Z28
Engine: 454 LSX
Oh, BTW, JB Weld has provided for an incredibly strong patch! Tomorrow, I will sand it and then paint it.
wigmobile
09-17-2015 03:38 PM
84 TA NV
09-06-2015 08:02 PM
