pwr lock problem
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
pwr lock problem
my driver door lock doesnt fully lck, how can i adjust it so it will lock? thank guys
have you tired spraying the door lock components with a good cleaner then a lubricant spray?
also try moving it open and closed a couple of times to work in the cleaner and lubricant..
1 Post
Car: 89 Black GTA
Engine: 5.7 TPI
My power locks are doing the same thing. If I hit the button they only "lock" half way. I have to hit the button about 5 times to get them to lock. I was just about to post the same thing, so I hope we get good answers.
MdFormula350- Ill have to try that. Has it worked for you?
Brian
Brian
Transmission: autos
i will try it when it quits rainin, but its annoyin cause i will forget to push it the rest of the way in and then my door is unlocked....
Mine does the same thing. I replaced the door handle on the other side. I forgot how the handle went so I took off the interior part of the passenger side just to look and now it doesn work. It looks like a Piece of junk when I have to push it like 5 times to lock.
Transmission: autos
tried greasing it, did nothing but stain up my door panels.....so now i can get get some upholstry cleaner with my NONlocking doors...ERG
someone972
08-30-2015 12:52 AM
