jammed lock
jammed lock
hi everyone im new to the board and i need some help with getting the rear hatch lock out???? do i need to drill it out or what do i need to do????
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1987 Trans Am
If you don't have a key, and theres no inside release drilling it out will work. Once its drilled out, insert a screwdriver through the hole into the slot where the lock arm went through and twist...the hatch will pop open.
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
just pull the lock out and look in ull see a slit stick a small flat head screwdriver in there and twist clockwise, hatch will open, or if u dont wanna mess the lock up, get in the back of the car, pull the panelin down and unbolt the hatch latch (that sounds funny..lol) either way works
Damon
09-26-2015 04:29 PM
Dragonsys
09-25-2015 03:51 PM
