Ashtray Swithes Installed
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Ok....here are the McCord Power Plate Switches installed......I think the piece of polished aluminum really highlights the switch panel...I like it! How about you guys?
Engine: 5.7
Originally posted by 86IROCNJ
Looks pretty good. Close ups would be great too. About how long did it take you to install everything?
Including the power plate itself? I'd say.......maybe....2 hours....it just depends how well you know your car. I had the shift plate out prior to installing the McCord Power Plate....so.....I did all of the switch and LED installation before I installed the McCord Power Plate. When you install the switch and LED......make sure your wires are ALL out of the way. Mine got in the way....and it tore up the switch when I shifted into gear...so...I had to ship it back to Keith McCord....but..he gave me a new one.
Car: 86 Iroc-Z28
Engine: FB385
Thanks for the heads up! So, how are the instructions, good? Did you have to drill a hole or were you able to come in uner the center console? Thanks for the info.
Engine: 5.7
Engine: 5.7
couple more pictures.....the aluminum looks kind of crappy right now...it's so cold outside..it's all fogged up...
That looks real nice :hail:
I would need more room:
N2O ARM
N2O PURGE
N2O Bottle warmer
TCC lockup
and maybe a few more plus indicator lights... possibly LED's with step down resistors??
Have you guys ever noticed on Redraifs Firebird the overhead console has switches mounted there that actually look really good. I wa thinking of that for a few things but am undecided if i want to run all of the wiring up there.
Yours looks great though.
N2O ARM
N2O PURGE
N2O Bottle warmer
TCC lockup
Engine: 5.7
Yep..that's an electronic cut out made by McCord Power Plate....cost me 100 bucks.
Car: 86 Iroc-Z28
Engine: FB385
There is a group purchase on them over at fbody.com. I should be getting mine for under $89 shipped. If you are interested, check it out. There is already like 25+ people on the list! Nice close ups, thanks for getting them. Once again, nice work!
Engine: 5.7
Originally posted by Trevor K
Does it come with that whole ashtray switch thing?
Also - how hard to wire it up? Do I need to cut a whole in my floor pans for the wire or ... ?
It was a VERY easy to wire up. All I did....was hook it to my interior lights fuse in the fuse box.....and grounded it. Works Great....very easy to wire. And no...it's dosen't come with the ashtray switch thing....I had to make all of that....all it comes with is the LED and the toggle switch...and you can mount it anywhere you would like. I chose the ashtray cause...it's out of the way....and it's hidden....by the flip of a switch....it's loud as hell. About cutting a whole in your floor board....well....it depends where your cutout is installed. Mine is installed in the intermediate pipe.....underneath my rear passenger seat. You take the passenger back seat out...lift the carpet up....and there is a plug..that you have to knock out. I fed my wiring through their with no problems. You have to loosen most of the carpet on the passenger side...so the wiring will run in underneath the carpet and up through console. About a 2 hour job. thanks for the compliment 86IROCNJ!
Car: 86 Iroc-Z28
Engine: FB385
Yeah, it is a pretty pimp system! Should be getting mine at the end of the month. Hopefully my car will be running right with a new exhaust too if this damn weather clears up! It sucks working on your car in the elements. I like how you did that 84customZ28, Don't be surprised if i copy your idea man, looks good, plus it is concealed. Not like people would say, "nice secret cut-out switch man", but still, it looks nice and clean, and that is important to me. Later
Engine: 5.7
I appreciate it man! Go righ ahead and use the idea.....I'd like to see more peeps do it!
Engine: 5.7
Originally posted by 92camaro44
well heres another dumb question... what do those switches control??? sorry
woah woah woah..that sounds really really cool..ok, so its on the end of your exhaust pipe???? and u can control like how much air can come out?...is this located like right after the cat, headers, muffler..sorry but this sounds like something i would be interested in..really awesome.
Engine: 5.7
It's called an exhaust cutout...I have a picture posted of it towards the beginning of the post. I have mine located in the intermediate pipe......underneath my back passenger seat. You can have them installed anywhere you would like....it kind of bypasses your muffler...so you cah have it really loud....or in between.....I can still here the flowmaster nice a clear though....I love it.....
well..im installing a full cat back system with headers later on in life...where would i place this..and im guessing this affects the horsepower..since it resricts and un-restricts air flow..correct me if im wrong...i saw the pic and the reflection makes it hard for me to picture...sounds like a sweet setup..a must have mod to come
I am getting one. I wanted one ever since my y-pipe disconnected from my cat last summer. It sounded so nice. I never got one though because I thought they were really expensive, but know that I know where to get them...
~Matt
~Matt
Anyone know of problems with them leaking when closed. Having a killer exaust set up, with a ticking exaust leak sound would not be my idea of money well spent. If it works good though, very cool idea.
I'd much rather go the electronic route if it means i would't have to fool around on the ground with nuts and bolts on a hot exaust every time i wanted a different exaust sound.
Engine: 5.7
Mine is fine.....dosen't leak at all........at idle....it really dosen't sound all that good...(the actual tone)....I have it closed ....when I'm driving....I have it open.....that's when it sounds fantastic..
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
Ca nyou tell me where the info is on the GP at fbody.com. That site needs major reworking IMO. So busy and bad colors make it a pain to use.
1992 Trans Am
05-10-2023 07:19 PM
