bolt in roll cage
Car: 1984 Camaro Z28
Engine: 350 CID
Transmission: Beefed up 700R4
bolt in roll cage
i know theyre not as strong, but i was thinking about just getting a bolt in 4 point cage so i can mount my racing harnesses up to them safely...anyone have any expierences with bolt in cages?
Engine: 350 CID
i need my car...i cant afford to have it in a shop while its getting welded in..and i dont really need the strength of the weld in cage, i need it for the harnesses
Engine: 350 CID
it compresses the spine in the event of a collision...you have to mount the harnesses on a cage in order for them to be safe
ok you said you want to put a bolt in cage to mount your harness up "safely". well i guess that is safer than having your harness boled to nothing. inmo, do it right you just might have a chance if you wreck you car
NHRA Rules (as well as here in NJ) say at 13 seconds you need a driveshaft loop, at 12 seconds you need a roll cage, and at 11 seconds you need a 5 point harness
id start with the driveshaft loop, its gonna take more work to get it to break 12's, so you got some time.
UltRoadWarrior9
09-02-2015 08:24 PM
