i need guage help please!
I just installed white face gauge overlay and now only the volt meter works and the tach, oil pressure, and water temp do not. Any help would be appreciated. Thanks,
James
James
Car: 1989 White Trans-AM
Engine: 305 TPI hopefully Upgraded Soon.
Transmission: Crappy Needs Improvment.
did you plug them back in before you put the cluster back into the right postition? that's all i can think of is they arn't pluged in or the connection is loose or the needle is off i don't know for sure.
Car: 89 Camaro I-Roc z
Transmission: Th700r4
um, did you put back the two nuts near the pass seat, cause if they arent in tight and the two connectors on either side of teh cluster arent toching then it wont really work.
hey hamspiced why do great minds think alike you know that really blows that i got reset oh well just gotta keep on postin LOL but yea i think it is because the connectors arn't making a connection.
I tried that and they the tach will go up to 5000 rpm when i start it and stays there. The other gauges still do not work. anyother suggestions.
Car: 85 Camaro SC
Engine: V6
Check the brass connections on back of the gauge cluster make sure they didnt pull away from the plastic tic tac. If they did then you can superglue them back on. And did you tighten the two wing nuts on the bottom of the gauge cluster? One is next to the check engine light and the other is next to the fasten seat belt light. My bet is on the brass on the back of the gauge cluster.
Car: 85 Camaro SC
Engine: V6
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
Peace
sorry bout all the sig stuff but sometimes things just need to be said and to let you all know i'm still in highschool and the only time i post is when i'm in school so i always have teachers looking over my sholder and non of them seem to have a problem with my monkey darn it! LOL maybe when i reach my 1000th i'll do that side post thing but i definatly learnt my lesson about bragging.
