instrument panel light bulb replacement question...
I have a 1990 rs camaro with a driver's side airbag. I need to replace 3 bulbs in my cluster. I have everything off that needs to be off except for the head light switch... It is in the way of the cluster cover (the black border thingy). Is there ome kind of switch to pull this off... if so where is it... any help would be appreciated. thanks.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
there is a pin under the "box" that the **** is interted to. it is either push up or pull foward on this little pin, while pulling out on the headlight ****.
fast83camaro: um... yea i broke my headlight switch, too the other day when i was playing with it... but all it did was pull away from the plastic mount (the black thingy) can i just glue the switch back to plastic mount or what? im 16 and I dont have the cash for a new switch nor the time to pull my whole dash off...
Ghettobird52
07-05-2024 11:18 PM
