Removing decals and paint
I dunno if I'm actually gonna do this. Just a thought. Is there a way to remove the decals without affecting the paint? I like the way the Firebirds look without them, and I thought about taking them off but I dunno how to do it safely, if there is a way. Also I dunno if there will be a noticeable discoloration from the paint underneath the decal.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Yeah, there is.....go to a body shop store. They should have an "eraser"....they fit on the end of a drill...and they take decals and pin stripes off like nothing....cost around 15 bucks or so....they are fantastic!
Engine: 5.7
I have NEVER had any problems with the eraser. I have used the heat gun before...which works pretty good....but...your more likely to damage the paint with that instead of the eraser. A heat gun could easily make the paint soft..and would come right off. If someone didn't operate the eraser correctly...the only thing that would really happen is that it may leave a "mar" in the paint....and those can be buffed out with compounds. Heat guns are great for the larger decals too in my experience. But...i like the erasers for pin stripes...and smaller thin things like that.
