What do you guys think of my ashtray switch panel??
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
OK Guys, I installed a McCord Power Plate on my exhaust cut out..and it's sooo awesome...anyhow....I wanted a switch panel to put my toggle switch an my LED light on....I did have just a black piece of plastic where my ashtray was...but..I wanted to "spice" it up a lil. So.....I cut a piece of aluminum the same size as the ashtray.....polished it....used epoxy to secure it in place...now...I just have to re-drill my holes and it will be done.....and of coarse....the lid does shut.....so it's not open all the time....just when I want to adjust my cutout volume...So.....you guys like it? Think it's stupid?...any thoughts, opinions, ideas would be greatly appreciated. Thanks!
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
I believe it switches the exhaust from open headers to the full exhaust. Usefull for track days so you can get a bit more power with out any mechanical work to the car. Just a flip of a switch and you've got open headers.
Engine: 5.7
I can get a couple close ups here in a few.....well..I don't have headers on my car....(yet)..but...you could use the Power Plate for that too if you wanted. I have my cut-out located in the intermediate 3 inch pipe. I got the McCord Power Plate so I can adjust the volume of my exhaust system. I can have it 3 inch cat back 80 series Flowmaster sound......or I can have it.....loud as hell....or...anywhere between...so..I can set the sound level of my exhaust....it's really kewl.
1 Post
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
is your plate flush with the console top portion of the tray or is it sort of recessed? if its recessed i think i might be cool to put a little neon light or something so u can see the switches at night if they arent lighted switches
I made mine out of smoked plexiglass from an old headlight cover I had laying around. It worked OK but I couldn't close the ashtray door... Hopefully this is a better design to copy
I did the same thing (sorta) in my old Camaro. I removed the metal ashtray and super-glued a matching piece of black ABS plastic to the bottom to make a "floor." I then mounted mini toggle switches in it to control the subs and the fans in the amp rack. With the lid closed, you would never know.
Engine: 5.7
Thanks fellas..well...I cut out a piece of aluminum..hand polished it...and epoxied it to the bottom...(where the ashtray was)......if I ever get some new batteries..I'll make sure to post some pictures of the top..and the underneath. The lid closes fine.....The switch is a chrome toggle switch with 1 red LED light. I thought about maybe hooking up 2 red LED's....and then mounting the switch in the middle....it might be kinda cool. Let me see if I can get some batteries now!!
Car: 86 Iroc-Z28
Engine: FB385
Any close up pics yet? Getting my MPP soon and am starting to think about where i would put the toggle switch. How is the switch that they give you, ok or would you rather have another one? More pics would be great! Nice work.
Engine: 5.7
I just got some batteries for the digital Camera....I'll take some pictures of it today...Go here....you can see what it looks like installed: https://www.thirdgen.org/techbb2/sho...5&goto=newpost
As you probably know.....McCord offers a wide variety of switches....but..I just went with the one they gave me.....it's a 2 way chrome little toggle switch with an LED light.....it's small....and to the point. I'll get some close up's. Thanks!
Ghettobird52
12-29-2023 08:23 AM
1992 Trans Am
05-10-2023 07:19 PM
86IROC112
08-17-2015 02:00 PM
