Lightbulbs
Lightbulbs
Guys,
How many of those 194 light bulbs are used behind the dash, HVAC and stock radio faceplates? I'm thinking of upgrading and replacing them all since they are all the original bulbs from the factory.
Also, how do you get to the bulbs on the HVAC panel and in the radio?
Thanks.
Thanks.
well, i changed the light bulbs behind the a/c , it was easy, just unscrew the trim, and you should be able to figure out the rest.
i was going to do the stock radio also, but i when i took it out, i saw thatyou had to take apart the radio (or so it looked) and id dint have time becuase i had to be at work in 10 minutes.. ;\
Try the following links for more info:
http://members.aol.com/rmacewen1/
https://www.thirdgen.org/techbb2/sho...hreadid=107995
JamesC
JamesC
