? about the iroc grill i bought
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
I bought a new iroc grill from hawks but it has 3 indentations around where it says "camaro". Two on top and one on the bottom off center. Are those supposed to be there cause they are three perfect indentations. Heres a pic of where they are. There not red I just highlighted where they are.
Car: 1991 Z28
Transmission: 4L60 automatic
Those are spots for holes for a license plate mount.If you happen to live in a state that requires a front lincense plate you drill through those holes and bolt down the mount,then screw the plate on.
Car: 1991 Z28
Glad to have helped.I'm going to need a new grill for my Z.might try them.
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Another question that i have....I bought some blazer foglights for my new iroc grill and i not sure where they mount too. there seems to be a spot in the ducts that go to the radiator but it looks like it will sit kinda far back. or do they mount to the actual grill peice itself?
Car: 1991 Z28
Hehe..I was actually doing some work on the front ground effect and it's off the car.
Well actually they are mounted on the bumper with a z shaped bracket.You see the tab with the light adjusting screw,that is where the top end of the bracket is.the other end slips under that black thing hanging there.
86IROC112
09-07-2015 01:37 PM
mustangman65_79
08-11-2015 03:17 PM
