Continual Air
Old 01-10-2003 | 03:44 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
Continual Air
I have a 84Z28 with air cond. When you are moving down the hwy. is there supposed to be continual air movement from the lower center vents near the console? If I bypass the heater there is cool air. If I run the proper heater hose connection then there is warm air. I assume I am picking up warmth from the heater core. Is this common? It doesnt seem reasonable because of the summer heat and then picking up extra heat from the core.
Old 01-10-2003 | 04:57 PM
Jza's Avatar
Jza
It's normal.. Read here.
https://www.thirdgen.org/techbb2/sho...threadid=41536
Old 01-11-2003 | 12:30 AM
StocRoc's Avatar
that's amazing
Old 01-11-2003 | 12:39 AM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Neat, I never knew about that. Does it stop when you have ac or heat on?
Old 01-11-2003 | 03:39 PM
Thanks for the info. May add that other valve. I already have the one, but I may put one on the other line. One valve seems to keep the water near the heater core and keeps it warm.
Bubbajones_ya
07-06-2024 09:32 PM
db057
04-28-2019 08:45 AM
83 Crossfire TA
01-03-2016 02:26 PM
edoff13
09-11-2015 04:55 AM
scotrans am
09-05-2015 05:26 AM
Quick Reply: Continual Air
