what kind of bolt holds on your highrise?
I am putting the high rise spoiler on my 86 camaro but I dont have bolts for it, does anyone know what type it uses or does anyone have pictures?
Thanks in advance
Thanks in advance
I have one out in my garage now.. Although I am not sure on the size of the nuts, I know that at the end posts there is one screw on each end.. But also be sure that you have the gaskets for them too before you put the spoiler on.
Car: 1991 Z28
Transmission: 4L60 automatic
Do you mean that you have the bolts that stick out of the 2 center parts and ends but you don't have the nuts that screw on them? There are 2 bolts for each center part and one on both ends of the highrise plus a hole for a screw on both ends.
Car: 1991 Z28
Originally posted by Camarokid01
so are you saying the holes on the end of each side are screws? and the middle ones are bolts? I dont have any studs on the spoiler or anything.
Thanks in advance
Thanks in advance
Car: 1991 Z28
I have the cover off and you can see what's under it.For the top 2 studs of the center parts there are caps covering the studs,so pop them off to reveal the nuts holding down the studs.
Thanks for the pictures, I have an aftermarket one I guess so it doesnt have a place for the screws, and I dont think I will be able to use studs unless I glue them in because the holes dont have a bottom, they a just go into the spoiler but if regular bolts dont work I will glue in some studs.
Thanks for all the help everyone
