how do i
Car: 89 Black GTA
Engine: 5.7 TPI
If the lights come on with the drivers door but not the passengers door you might have a short or a bad wire somewhere. Or the spring loaded switch might be bad. It is kind of a crappy problem cause it could be several things that are not the easiest to check. I am not sure if the drivers and pass doors use the same fuse. You might want to check that also.'
Brian
Brian
I have the smae problem with my camaro, cept its with the drivers side door. Passenger door works fine. Ill make that item 165 on my things to do to the camaro before the end of time.
lol, ya its a tiny problem but i got an alarm that works off the battery to see if the volts change so that would set it off, i'll check the fuses today and mingle around with it, tell ya what happens later on..
