cheap/easy way to fix sagging door?
Old 12-27-2002 | 02:28 AM
squirrelybird's Avatar
i just discovered my driverside door is sagging just a bit i have seen expensive kits to fix door sag, but i have also heard stuff about cheap pins and bushings?? someone educate me on what these can fix, and what they cannot. also where i can get them and a ballpark price.
Old 12-27-2002 | 04:23 AM
2maros1fox's Avatar
i just loosened the bolts to the door, had a friend adjust it where i wanted it while i tightened the bolts back up. there is maybe 1/2 an inch of play to mess with. hope it helps.
Old 12-27-2002 | 10:32 AM
MdFormula350's Avatar
maybe check this site at http://www.andyz28.com
Old 12-27-2002 | 01:27 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
cheapest/easiest way to deal with that would be to cut the doors off, sell them, and ride around without any doors. Now you have no sagging door problem, and a couple extra bucks in your pocket.
other than that, i would go to andyz28.com
Old 12-27-2002 | 01:29 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Also depends on if it's the upper or lower pins which need replacing...the lower ones are much easier and cheaper.
The 'lifting and adjusting' method is only a temporary fix at best, because it does nothing to cure the problem.
Pete
Old 12-29-2002 | 04:49 PM
REDRIDER89125's Avatar
Saggin Doors
I have an 87 T/A and all I did was replaced the pins, then I took a floor jack and put a block of wood on top of it and jacked the door up. Works really nice but doesn't last forever, almost time to do it again. Just cut the damn doors off!
Old 12-29-2002 | 06:28 PM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Just watch "The Dukes of Hazard" very carefully.
GeneralIesrussi
Carburetors
06-20-2024 08:21 PM
Hotrodboba400
12-10-2019 08:07 PM
billybob6110
09-23-2015 02:30 PM
SG91camaro
09-05-2015 11:27 PM
Hotrodboba400
09-02-2015 08:28 PM
