Cracked front seatbelt latches . . .
Car: 1985 Trans Am/WS6
Engine: 5.0 TPI
My front seatbelt latch sleeves are cracked all to heck. Does the latch/webbing come out of them if I remove the hold-down belt? I had the latch fixed under the recall years ago and would like to keep that part - just replace the sleeves.
BTW, I don't know what they do under the recall, but once the plastic cracked it revealed that I had red seatbelt webbing. Everything else is gray. (I've owned the car since day one so I know nobody else messed with them)
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
the sleeves should have a thread stich in them in center towards floor end of them to hold the sleeve to the belt to keep it from sliding up or down,.
good luck
good luck
