little white plastic dealy with the two copper contacts ?
Old 12-16-2002 | 03:38 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
in steering column under the turn signal switch assmebly there is a white plastic deal with two copper contacts in it that all plugs into a square hole and makes contact with a deal on the ignition switch assembly when it is in ON position, what is this contact deal for ? theres a light green and tan wires for it..
hope it isnt important.,.,
thanks
Old 12-17-2002 | 10:39 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
lemme know if i gave bad explanation of this part,
ttt
thanks
Old 12-17-2002 | 04:52 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
nah decent description.. i know exactly what you mean.. no idea what its for though so i just put it back in like it was hehe
Old 12-17-2002 | 09:28 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
is there a special trick i dont know about getting it plugged back in place ??
Old 12-18-2002 | 12:46 PM
89RsPower!'s Avatar
i dunno i just stuck it back in where it came out hehe
Old 12-18-2002 | 02:46 PM
MasterEvilAce's Avatar
Fast: I now exactly what you're talking about.. i'm not sure what it's for, though
i had a hard time getting it in, along with the screw and the lock cylinder...
as far as i know, you have to put it in before you push the cylinder all the way (it wouldn't go in until i pulled it out a bit).. then you have to put the screw in for the lock cylinder, and like sort of push in all three at once or something
just trial and error,i suppose
it doesn't make any sense
try it with the key in the off position, then try it with it in run, and see if it makes a difference.
That column is a BASTARD.
Old 12-19-2002 | 09:06 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
interesting, hmmm...
didnt try that one, hmm, id have to disassemble column again to try to reinstall it again, hmm.. ill hold off on that unless something important in the car wont work whne i get fuel tank/sender/lines problems/damage corrected
thanks
Old 12-19-2002 | 11:01 AM
Nate1's Avatar
Car: 88 IROC-Z, 71 SS 454 Chevelle
Engine: 305 TPI, 454
Transmission: 5spd, th400
If I understand you correctly then it is the keyminder ( makes the buzzer or chime go off if you leave the key in yhe ignition when the door is open.
There is a flat spring clip that goes with it and it sometimes stays in there when you remove the plastic part. If the spring clip is still in there you will need to fish it out and install it and the plastic part together or you can leave it out and it will not hurt anything except it will not remind you when the key is in yhe ignition and the door is open.
Old 12-19-2002 | 11:17 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
wow ok that would be it then, yeah the spring steel retainer deal stayed in the hole, oops
oh well, dont need key reminder for now, ill worry about it some other day, gotta get fuel system repaired first, and see if car wil be a driver or another parts car, hmm..
thanks!
GeneralIesrussi
Carburetors
06-20-2024 08:21 PM
Fronzizzle
02-09-2017 10:31 AM
IROCZDAVE (88-L98)
09-17-2015 08:43 AM
dimented24x7
09-17-2015 07:58 AM
hdis2002
09-08-2015 03:52 PM
Quick Reply: little white plastic dealy with the two copper contacts ?
