help locating square dot fade for 90 formula
1 Post
Car: 1990 Formula
Transmission: WC T5
I am trying to find a source for a square dot fade for a 1990 formula that has red top accent stripe and fades from charcoal to grey.
So far I have had no luck.
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
looks like a rocker panel to me or the lower parts of the front fender or rear 1/4
1 Post
Car: 1990 Formula
Transmission: WC T5
it goes around the whole car. (My car looks exactly like the one you see in the thirdgen.org message boards logo at the top of the page) It seperates the two tone paint job along the entire lower portion of the car.
1 Post
Car: 1990 Formula
Transmission: WC T5
well at this point I have tried everything. NOoooo One carries the dot fade. I have tried every suggested option including GM (discontinued).
The only possible close match that might be made is with a 86 trans am charcoal square dot fade from Phoenix Graphicx and a red accent stripe across the top.
The original, tapered at different areas,ex. the front and rear bumpers. The replacent one will not. Also, the original had all of the three colors on the stripe, red, charcoal, silver.
The replacement will only be charcoal and fade to clear and will have to pick up the silver from the paint below. Then the red accent stripe will have to be added. Also, the stripe will not taper like the original. But what is a guy suppose to do?
At this point, it looks like this is my only option.
1 Post
Car: 1989 IROC-Z
i couldnt figure out what angle i should be lookin at it from.
what about GM?
might be a rip off, but it could be the only place to get it. not sure.
edit: sorry didnt see that you already tried GM
