front spoiler extension
Car: 86 z28, 87 IROC, 88 sc, 93 z28
Engine: LG4, LB9, LO3, LT1
Transmission: 700r4, T5, 700r4, 4L60
Axle/Gears: 3.73, 3.45, 2.73, 3.42
Ive seen pics of this guys car a few times and always loved the extension on the front spoiler. I was wondering if anyone has done this to their car and if so how? Any help would be appreciated.
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Re: front spoiler extension
Car: 86 Iroc-Z28
Engine: FB385
That does look bad ***! Where did you see that guys car? On that site in the pic? Try posting this in the appearance board, you may get more responses! I want to know more. I am sure he made it b/c i have never seen one before. Looks like a spoiler for auto-x or some type of road racing!
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
looks like he just put a flat piece of fiberglass or something under the front spoiler that sticks out an extra inch or something.. looks really nice though.
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
messed around a few minutes.. my conclusion is that he did put something under it.. i edited the piece he had under it, now it looks like a normal car..
You could attach a piece of PVC under the spoiler. But I'd ONLY do it for track use. Don't you 91-92 guys scrape your spoiler enough already? Now you want to make it lower and stick out further forward? (but it looks cool!). I filled in the area under the spoiler with two pieces of sheet PVC extending back the full length of the spoiler to cut down on under-car air turbulence. It is not visible at all unless you put the car on a lift or feel under the spoiler.
Lon
Lon
A splitter, cool Ideal. Had been thinking that too for awhile.
I think Wootah is correct about the construction.
The only thing "I'm" doing different is as the splitter comes around the sides, make them angle (AOA) up slightly (some call wiskers) not follow the stock lines, so it really works. Just my 2 cents.
Car: 86 Iroc-Z28
Engine: FB385
Looks bad *** from the side, not too sure from the front now. I'll take the wheels though! lol Whats he smokin? You could buy 2 Z06s and throw turbos on them for that price! I wonder if it ever sold, looks like an old ad.
Location: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Originally posted by CrazyHawaiian
Do you guys want to do this for looks or for functionality?
Cause I already have the **** mobile....
Remeber, I'm Kj ****....
Engine: 5.7
I'd want it for looks too......that must have been custom made....cause....I've been lookin on the net....and so far....no luck on finding anything like that.......
I see that everyone seems to like the spoiler. Now we just need to find someone to make them. Any ideas???
http://wwwstud.fh-zwickau.de/~ao/ecz28/ecz28.htm
It seems to be true, thats pretty amazing to run a 1/4 in the 11's and have gears to get you up to 251 mph, pretty nuts.
Car: '86 IROC
Engine: 305 LG4 awaiting the crate Vortec 350
That thing's bad ***!!! i would think it might fly off if u go over 100 and u don't do a real good job of boltin that sucker on!
Supporter/Moderator
As soon as I get the Z28tt back on the road, I'm looking at fabricating some ground effects for the third-gens. I've got the rocker panel extensions designed, and will extend the front a bit as well. I need to measure suspension travel before bump stops, to see how much I can get away with. Everything will be held in place with 1/4 turn Dzus fasteners so it can go on/off easily. Hell - my '92 IROC ground effects scrape going on trailer, so the front will need to come on/off easily. The side skirts will be alum or carbon fiber, and I need to find a source for urethane up front, for a little flexibility. At some point, I've been thinking of setting up a belly pan and diffuser at the rear as well. There was an article a few years ago of an open road racing third-genner that had true ground effect ducting. Thoughts?
Engine: 5.7
AkDrifted
08-17-2015 07:45 PM
