repair headliner board
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
has anyone thats recovered their headliner had to do any repairs on it? i thought mine was totally toast, but its only torn up at onr corner of it (near the driver side seat belt hole).. well, the whole corner is missing.. is there anyway to repair this or do i have to completly replace the entore headliner??
-mike (loomdog)
-mike (loomdog)
well...
I removed the entire headliner from the car( a decent chore). A good bit of it was sagging. I removed the material entirely. What was underneath was the deteriorated foam rubber. I took a shop vac and sucked all the loose stuff off, using a brush attachment. Then took some dark gray primer and painted it! Mind you this was a dark gray interior to begin with. Most people will never know it was done if you don't like it the only thing your out is the cost of the paint.
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
go down to the local bone yard and see if you can score one there, you can usually get them pretty cheap and they will be in perfect condition
Car: 82 Camaro Z28
i was thinking i almost had to replace it.. was wondering if anyone had ever repaired the board before and how to do it if its been done.. oh well.. i guess im off to the bone yard..
-mike (loomdog)
-mike (loomdog)
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
i do headliners all the time. yes it is possible to repair. i use thick sandpaper that the air poewerd strait line sanders use. it is strong, but still flexible. you need to prep the board by cleaning all the old foam and cloth off the board, and i do mean all of it. the glue wont stick as well to the old foam, and cause premature failure. a wire wheel on a drill works great, just dont stay in one spot to long. then the hard part is putting new headliner on the board. the directions say apply glue to both mating surfaces, but it is a bitch to keep the wrinkles out, and once it is down, it is down. i apply the glue to the boar heavilly, then start in the middle working the way out to the edges of the board, using your hands, but make sure they are clean. then pull up the outer edgen all the way around the board and apply glue to the cloth and more on the board, then on the back of the bord around the edges, then finish by smoothing out the edges and rolling the cloth over the edge and onto the back for a clean look, and be sure that you cut the cloth a litlle around the corners or major bends or it will wrinkle. let it sit for about 2 hours in a well ventilated room (or not if you want a buzz) then reinstall.
good luck
anthony
good luck
anthony
Linson
10-01-2015 09:50 PM
formula00ra
Interior Parts Wanted
09-28-2015 11:50 AM
