I broke my rear subframe loose! Help!
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Ok, I'm not sure if that's what the part is called, but the arm that goes up and down, and holds the rear suspension to the car. The panel supporting that broke at the weld underneath the rear right passenger seat. It looks like it rusted through the floor pan and there is a spot of carpet the size of a dime now visible from underneath the outside of the car. I had noticed that seat vibrating ecessively and a recent passenger noted that his leg was getting violently bounced up and down by the floor. The panel is merely separated and I can push it up and down with my hand, it hasn't been pulled away from it's original position it's just a bit concerning, this has been broken for 2 months now I would guess.
OK, so why do I need help?
I want to know what this is going to cost to repair and if getting SFC's will be a good idea or if this is a good excuse to get them. The underside of the car is in pretty good condition except for the side rails which I was planning to have repaired.
Any helpful information would be appreciated.
ambainb
04-25-2016 10:21 PM
lt1z350
09-29-2015 02:50 PM
