Hood & Hatch strut part numbers & alternates
Hey all,
I'm looking to replace the hood and hatch struts/lifts/supports on my '87 IROC.
Looks like part numbers are as follows:
Hood:
GM# 14019157
AC Delco# 510-305
Hatch:
GM# 16604426
AC Delco# 510-510
Anybody know if these are correct? Are the AC Delco & GM parts identical?
Only place I've found them listed online is gmpartsdirect, but they are pretty expensive.
I ran a search on the boards and found that some people used parts from AutoZone or PartsAmerica. Any idea on the part numbers & brands on these items? Are they strong enough to hold the hatch & hood? Do they fit right in using the same fittings and are they the correct size/length???
I don't mind the 3rd party items as long as they're a direct replacement (and can hold the incredible mass that is the hatch!)![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
Thanks in advance!
mr.bri
Hood:
GM# 14019157
AC Delco# 510-305
Hatch:
GM# 16604426
AC Delco# 510-510
Thanks in advance!
mr.bri
Do not get GM hood or hatch struts. They are too expensive and fail after a short time. My original hood struts lasted 1-1/2 yrs. I replaced them with GM ones. Again 1-1/2 years later they wouldn't hold up the hood. I purchased ProLift brand hood struts from Pep Boys at that time. They have a lifetime warranty. They STILL hold up the hood (admittedly a bit weaker now) over 7 years later. I recommend getting aftermarket struts from your auto parts store that have a lifetime warranty. Also for the rear hatch, get the ones for the heaviest rear spoiler and rear window wiper motor. They will be a lot stronger. I replaced the rear struts (again ProLift brand) on my 88 IROC 2 years ago. They still push the hatch up right away fully when you release the hatch by key or with the solenoid.
Lon
Lon
Thanks Lon!
I haven't checked Pep Boys yet, but do you know the part numbers or sizes that fit? Are the fittings/attachments the same, so it's an even swap?
Thanks for the information, it sounds like the way to go, especially with the warranty!![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Brian
Brian
Pep Boys ProLift hatch strut number: 0-37495-92002 (from my receipt) $37.99 ea. I purchased these in 5/00. I called PB recently. They said they have changed brands of struts. They still have a lifetime warranty though. I haven't had a chance to verify this in the store yet.
Lon
Lon
Car: 1992 RS Heritage Edt.
Engine: 305(LO3)
You can go to autozone too. I have an extra job with them and thats where I got mine replaced. They were so strong I had to keep the hatch from shooting up on its own.LOL theyre about 35-40 buck s for the back pair and about 20-25 for the front
Wow! Thanks guys! :hail:
I have both stores close by so I have options. I was just worried that the parts wouldn't be strong enough to hold the hood or especially the hatch. I use a golf club right now and it looks like it's going to snap anyday.
And the lifetime warranty is a big bonus!
Brian
![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
Brian
1 Post
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Re: Hood & Hatch strut part numbers & alternates
I put Autozone's on my 88 less than 2 years ago and they've failed. The IROC has been mostly stored in the garage the past year so those shocks/hood struts shood have lasted much longer. I wish there was a way to adapt and make it so that there were double struts on each side; these are hella heavy hoods! Nitro
1992 Trans Am
05-10-2023 07:19 PM
Black89TA
Exterior Parts for Sale
07-23-2016 10:42 AM
TA8487
08-16-2015 12:21 PM
