Body Filler question?
Old 10-17-2002 | 11:17 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
I have a question about body filler? Is there a product out there that adheres to stainless steel, and then when it hardens you can polish or chrome plate it? I'm dealing with some stainless that I welded two peices together, and then belt sanded down the weld so it would blend with the metal, now I have low and wavey spots. I need it to look like one piece so I can plate it.
any info would be greatly appreciated.
Old 10-18-2002 | 12:00 PM
LT1guy's Avatar
Car: 1987 Trans Am
If its not too bad, the plater can go heavier on the copper coat and buff before doing the nickel/chrome...if its really bad, you might have to build up the weld and regrind. I know some fillers are conductive (for example, you can powdercoat over All Metal), but I don't know of any that can be plated over.
Frozer!!!
01-19-2024 05:55 PM
1992 Trans Am
05-10-2023 08:19 PM
ezobens
08-19-2015 11:29 PM
redmaroz
08-17-2015 12:40 AM
bamaboy0323
08-15-2015 08:20 AM
