window aligning?
Old 10-17-2002 | 12:28 AM
burnouts4ever's Avatar
window aligning?
how do i align this dang window i am sick of it leaking. It is really getting to me. It is leaking from the front corner and back corner.
Old 10-17-2002 | 12:52 AM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
There's a tech article in the Tech Article section,
It's kinda a bitch, I gotta re-Allign my windows some year...
Old 10-17-2002 | 02:20 AM
Kandied91z's Avatar
take off your door pannel..........it's rather simple if you can manage saving the top black piece that holds the weather stripping.........you break the clips on that bad boy and your looking at an easy 100 a side.
once you get the whole interior skin off there are guiders that can adjust the glass. roll the window all the way up and close the door with you on the inside and just align it til it's right.
mine's a little off, but there isn't any way i'm going to try and go through all that again just to fix a very minor gap, now if it's leaking when it rains out...that's a different story...if you get a little bit of water when you wash the car i wouldn't worry about it. it can be done though so if your interested don't be afraid to try.
Ed1LE
09-30-2018 10:14 AM
Fireslash
04-11-2016 07:43 PM
Cam-aro
Camaros Wanted
11-12-2015 04:35 PM
Bubbajones_ya
10-25-2015 09:01 PM
meeklay812
10-01-2015 04:46 PM
