painted my interior pieces
I probably should have asked or searched before asking this but anyway, i finishe painting most of my interior pieces today, i went from grey to black, i first cleaned the pieces then i scuffed them up and sprayed some dupli color clear primer that said it was made for plastic pieces, I then sprayed normal dupli color black spray paint over it. Now my question is do you guys think it will last or wll it start to crack and fade after like a month???
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
I did this and the paint falls off to the touch
i used the same technique you used and vinal and fabric spray paint. Im just gonna take the whole interior outta my parts car.
![Frown](https://www.thirdgen.org/forums/images/smilies/frown.gif)
You shoud apply more than 1 coat, also use a clear coat on top of that.....
Since it's paint, and EVERY paint fades over time you will begin to see it after a while.........Not soon though......
Just remember clean, scuff a little, apply primer, apply AT LEAST 2 coats, the finish with the clear coat...
I did this to some interior plastic and it has held up to the florida sun for the past 5 months and looks good....
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
I used Testors model paint. its kinda pricey but you figure its made to stick to plastic, and has 1000 colors .. ![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
The speaker grilels are starting to chip a bit, but then again they are in DIRECT sunlight with a black dash around it. My dashboard and door handles are still perfect.
![](http://mywebpages.comcast.net/tstrella/firebird/guagepod2.jpg)
1 Post
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
i painted my interior and didnt use a clear coat or primer..i did that the very first year i owned the car and still no chipping or sun fade...granted ive only put 8000 kms on her in 3 years but it still sat all that time in the sun baking..
iroc2nv
iroc2nv
1 Post
Car: 00 TA, 91 Formula, 89 RS
Originally posted by deadtrend1
I used Testors model paint. its kinda pricey but you figure its made to stick to plastic, and has 1000 colors ..![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
If you prep the parts properly, the paint will stick fine. Wash the parts with rubbing alcohol, paint thinner (sparingly), mineral spirits or "Final Wash". This will remove all of the armor-all. Then sand it lightly with 400 grit paper, and spray multiple light coats until it has even coverage. I did my kick panels like that 2 or 3 years ago and they still look brand new.
If you want exactly the right color, your local parts house can mix the OEM colors. They use regular automotive paints, so you'll need a spray gun, reducer, hardner, etc. in order to spray it, but your results will be better than what a rattle can can do.
1 Post
On mine, I primered, sanded, sanded, sanded some more, then sanded with finer grit sandpaper, and then sprayed two or three coats of red high-heat engine paint (no joke). It worked pretty nicely actually. I would like to respray a closer matching color though.
1 Post
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
![doh](https://www.thirdgen.org/forums/images/smilies/doh.gif)
Use Acrylics on plastic parts, you can find it in the spray form as well. That's why model masters testors worked so well for the forementioned poster. These happen to be acrylics. Make sure you clearcoat it well too. I'd research what clearcoat you're going to use. You need something that's going to stand up to heat in the summer without glazing or some such thing.
Mathius
ambainb
04-25-2016 09:21 PM
