Sanding off paint
Car: 1986 IROC-Z28
Engine: 355 in the works...
Sanding off paint
Around my T-tops all the paint is peeling down to my quarter panels. I need to sand all the paint off. What grit should I use? Also what sort of tool should I use to do this?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Originally posted by ZRated85355
I would recomend 80 grit and a jitterbug. It takes paint off pretty quick.
Yeah, either a Jitterbug or a DA would do the trick
Engine: 5.7
Originally posted by pauldaniel26
DA?
DA?
Yeah....a DA.....It stands for "Dual Action" Sander. Most autobody men use these to sand down paint and to feather in bondo. They come in 5 inch 6 inch or 8 inch. They are REALLY great. You can pick them up for pretty cheap. About $50..00 from autozone. They are ran by an aircompressor.
Car: 1986 IROC-Z28
Sucks for me, I don't have an air compressor. Would one of those sanding wheels work that goes on a drill?
Engine: 5.7
If you used one of those sanding wheels on a drill......it would tear the paint up way to much and scratch it to pieces..........a drill dosen't have enough RPM to sand it smooth like a DA or Jitterbug.
Car: 1989 Firebird
Engine: 5.7 LS1
I've used a orbital sander (electric black and decker) before to prep/strip the paint, it works ok. You will need to stick with something finer than 80 grit though, like 200 or better, and take your time. Otherwise you will leave scratches in the metal. If you have never preped a car for paint before, you may want to do it by hand. You will reduce any scratches that you could get. If you could get access to a air compressor it will give you the best result. You could always go with a chemical striper, just prep and prime the surface asap. You will need to sand before priming, but not as much. But it will also destory your seals if you get it on them.
Car: 1986 IROC-Z28
Well, I can use my friends air compressor so thats not a problem now. Now where can i get one of these DA's? How much do they cost?
I believe that answers your question
Engine: 5.7
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
jitterbug: http://www.toolking.com/shop/view.asp?ID=424
Hotrodboba400
12-10-2019 07:07 PM
1Aauto
Sponsored Vendors
09-13-2017 12:58 PM
