Help installing a new cruise control lever
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 86 Iroc-Z28
Engine: FB385
Anyone done this? What is the easiest way about doing it? I have the lever, i just need help starting! thanks
Car: 87 Trans Am
Transmission: TKO 600
Yes i'm serious. When I replaced mine I thought I was gonna have to pull the column apart. So I went to the junk yard to get a new lever. I figured I'd try to pull the lever out and see what happens ( on the junked car ) it pulled right out. I did the same thing on my car.
I'll post some pics in a little while.
Car: 87 Trans Am
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Yep, the arm just pulls right out. However, the cruise sig cable goes down the column, and is a severe PITA if you just yank the old one out and try to put a new one in. Instead, drop the driver's hush panel, the cruise cable is a single back cable that has a 4 pin plug on it, tape (well) a string or wire or something to it, and fish it back up as usual. Now, with the new one, tape the plug end to the wire that is in the column now, and pull it back through the column. Now you are all set, and the wire is in the column!
It's easier than it sounds if you do it this way, otherwise you will have to take the column apart to fish the wire back through it. Let me know if you need some more help!
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Car: 86 Iroc-Z28
Engine: FB385
Thanks Erik, guys! Today i worked on the engine bay and started ripping apart the interior. I got the new guage cluster together, mounted the shift lite, and also the dual pod! It's coming together pretty nicely. Tommorrow i'll tackle the cruise control lever. Thanks, i'll let you know how it turns out. later
1 Post
Car: 87 Formula
Engine: 327
Uhh. Make sure that the wipers are OFF when you pull the lever out.. It had been raining before I decided to change mine, so the wiper switch was in the on position.. I pulled on the lever and it came out allright, but it broke the wiper switch.
I then found out the wiper switch must be one of the most expensive parts in the interior!! New one from the dealer was $125.. everywhere else I tried either couldnt get it or were closer to $200.
![doh](https://www.thirdgen.org/forums/images/smilies/doh.gif)
Car: 86 Iroc-Z28
Engine: FB385
Thanks for the warning! I'll mess around with it before i just rip her out. thanks, i post when i get it done so it may help others! hint: the search button!
eightsixseven
08-14-2015 03:09 PM
Street Lethal
08-13-2015 08:28 PM
Street Lethal
08-12-2015 11:33 AM
