leaky T-tops
leaky T-tops
Where is the best place to get new weather stripping for my 83 Z28? I really need to replace it all; around the doors and the t-tops and especially the deflector piece that hangs down over the side window glass. I've talked to the GM dealer but I wonder if there is a good after market product.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
whelp, from what I understand the GM strips are the best and only ones to get if you do not want to have leaks... Thats what I have and I have no leaks period!!!
Actually when I installed them I had a few drips on the back seat, I used a little 100% silicone sealant and had no probs since...
Unfortunately they recently went up in price...
John
John
Thanks for the feedback.
That's what I thought but you never know until you ask. I've tried 100% silicone on the old ones but no luck there.
Peace
Peace
mine were not leaking between the seal and the glass, but between the seal and the body, thats where I was having problem, not now...
John
John
mine also leaked from the weatherstripping and the body and some black silicone fixed all that!!
only change your weatherstripping if it is dryrotted and/or broken up..
if te rubber is in good shape then your t-tops might need to just be adjusted, or some silicone to be used...
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I much prefer the GM T top seals. I don't mind the price, I just don't want to ever do the job again.
My T tops stopped leaking when I installed SFCs on my '82. But I am going to replace them because after 20 years they have pretty much had it, and they both have tears in them when I got the car.
Thanx,ANDYZ28
Thanx,ANDYZ28
1Aauto
Sponsored Vendors
01-15-2016 06:26 AM
Thirdgen89GTA
11-26-2015 11:04 PM
