car weight ??
car weight ??
Hi, I just ran a G-tech on my car to find out it's horsepower, but I don't think I put the correct weight in. What is an estimate of how much a V8 1984 Z28 would way? th-350 trans, fiberglass hood, and stock other than that. thanks
Same year Firebird with an automatic and 305 V8 weighed in at 3145. subtract about a hundred pounds for the different hood and you are probably looking at 3000 to 3050 pounds. Hope that helps.
ROFLMAO, hood prop, so true... I have an 82 with a 350/th350 combo and I weighed it at a weigh station the other day.. It was 1500kg which is about 3300 pounds with no one in the car, absolutly no stereo, fiber hood, full interior with sound deadener, 1/4 tank of gas and a half full tank of nitrous.. No frame connectors or roll cage.. The gutting starts this winter..
Cheers,
Cheers,
The weight posted is out of a Firebird Book. SO I know it is right. I guess I was way off on the difference between a steel hood and a fiberglass one . My mistake. So I suppose around 3100 pounds would be a better guess, a guess that is still more beneficial to this post than some other comments.
Car: too many ...
Here's some stuff off the Tech section of this website
Weight of Unoptioned 1987 F-Body Combinations
Model Base Weight
IROC-Z 305 5.0 5-Speed 3250
Formula 305 5.0 5-Speed 3383
IROC-Z 350 5.7 Automatic Overdrive 3341
GTA 350 5.7 Automatic Overdrive 3476
Weight Data on 1992 Camaros
Model Shipping Weight Curb Weight
Camaro Coupe 3025 3105
Convertible 3142 3220
Z/28 Coupe 3194 3273
Convertible 3298 3377
Differential Weights of Accessories
Code Item Weight
AC3 Power Seat 7.9
AM9 Fold Down Rear Seat -3.5
AU3 Power Locks 3.1
A31 Power Windows 3.9
B84 Side Molding 1.3
CC1 T-Tops 29.5
C49 Rear defogger 0.9
C60 Air conditioning 41.7 with V-6
C60 Air Conditioning 42.6 with 305 TPI & 700R4
C60 Air conditioning 46.3 with 305 TBI & 700R4
C60 Air Conditioning 42.7 with L98
DE1 Back window Shade 18.5
D34 Vanity Mirror 0.4
DG7 Electric Side Mirrors 1.3
F41 Suspension -6.6
J65 4-wheel disc brakes 2.6 (Z/28 w/L98 only)
K34 Cruise control 5.3
MD8 Automatic Trans 101.9 (with 305 & 350)
N10 Dual exhaust 12.8
T96 Fog Lamps 4.4
UA1 H.D. Battery 0.4
UL5 Radio delete -5.7
U75 Power Antenna 2.6
Model Base Weight
Code Item Weight
AC3 Power Seat 7.9
AU3 Power Locks 3.1
CC1 T-Tops 29.5
F41 Suspension -6.6
T96 Fog Lamps 4.4
84z96L31vortec
08-20-2017 12:16 AM
84z96L31vortec
08-10-2015 08:27 PM
