Hood Scoop
Old 08-14-2002 | 10:07 PM
ZRated85355's Avatar
Hood Scoop
I have never posted pics so ill try it now. These are sum pics of my '85 camaro.
Old 08-14-2002 | 10:09 PM
heres another...
Old 08-14-2002 | 10:10 PM
tell me what you guys think and feel free to ask questions.
Old 08-14-2002 | 11:44 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Well, by the looks of the sig. the car is producing enough power, so the scoop was needed. Due to the situation at hand, I give it a Why? Because there isn't a smiley for 2.
I wanted a scoop, but my car doesn't have the ***** to back it up.
Old 08-15-2002 | 05:48 AM
logikal6785's Avatar
like, have any small children, birds, or sheep gotten sucked into that monster scoop ? lol jk if ur pumping that much hp then hell yea go for it
Old 08-15-2002 | 12:04 PM
The scoop was needed when i tryed to close the hood with no aircleener and the carb hit At the time i had no idea what to do so i just choped a hole in the hood big enough for a 14" air cleener. I found this company called Unlimited and they sold these things so for $170 my prob was solved. Oh yea this is the reson for the scoop.....
Old 08-15-2002 | 12:32 PM
TZFBird's Avatar
Engine: 327
Well, that's no good reason for a scoop...just an air filter. I figured there was a supercharger under there. Now that I found this out, I say take it off or supercharge that beast.
Old 08-15-2002 | 03:16 PM
The air cleaner isnt the prob the intake manafold is. It is a holly strip dominator and is way too high. Without the aircleaner on the carb hit the hood. I figured if i had to put some kind of scoop on i should get a big air cleaner too. As for the supercharger... it wouldnt work. I am running 11.5-1 pistons and this makes a supercharger allmost usless because i couldnt run it with any boost.
Old 08-15-2002 | 03:37 PM
ATOMonkey's Avatar
Welcome to the club. Your scoop looks way better than mine though. I was hitting my 750 on top of a Performer RPM on my bird. That's just no good. I cheaped out even more than you, my A&A Jegs special was only $50. LOL
Are you going to make a pan and seal it? That's my next step. I can't quite back up the power like you yet. I have the cam and carb to do it, but not the heads or intake. The intake that I have now was free, and I already have a port job for heads going this winter. After $150 I should be right up there. Oh well enough about me. When are you going to get the car sprayed?
Old 08-15-2002 | 03:39 PM
ATOMonkey's Avatar
Here's mine.
Old 08-15-2002 | 03:52 PM
Hopefully ill get some paint on that beast before december, I still have to weld new bottom door edges on and shave the handles I was thinking about a pan to seal the scoop to the carb but im not sure i want to do that.
Old 08-15-2002 | 04:09 PM
ATOMonkey's Avatar
Just do it when you want to cruise and then plug the scoop and run a standard filter when it rains/sits (hopefully it never rains on that car). Do you have problems seeing the road making rights too?
Old 08-15-2002 | 04:16 PM
I have a plug for the scoop that came with it. I use it when it rains. The reson I dont want a pan is it makes more under hood heat and i like things cool.
About the vision thing... It becomes a pain in the *** when you are on a busy street and a lot of people are crossing you cant see them unless you put your head on the passengers lap. When making right turns I cant see to good either so i just close my eyes and hope for the best jk.
Why do you hope it never rains on my car? Its water proof and the T-tops dont leak.
Jorlain
Exterior Parts Wanted
06-30-2017 12:04 AM
91TTOPZ
Exterior Parts for Sale
09-20-2016 01:42 PM
