Who has the blue Cluster lights ??
Old 08-13-2002 | 06:47 PM
Z03Z28's Avatar
Car: 92Z28,98LegacyGT,ZX9R,91 Z28,02 Z71
Engine: 350,307,2.5,900cc,5.0
Transmission: 700r4,4spd auto,700r4,4L80
Axle/Gears: 323,?,323,?,373
A few months ago someone had changed
his lights to blue one and it was SWEET
does anyone know what I'm talking about?
:rockon: :rockon:
Old 08-13-2002 | 06:57 PM
1991rsblue's Avatar
blackened had blue led lights in his dash. i've tried to reach him too but i got nothing back from him.
Old 08-13-2002 | 09:08 PM
PopaPork's Avatar
I just did mine today actually. BUUUT something happened I think the Speedo cluster just burned out. They look pretty good. I think it looks better on a 90 and up car though.,
Old 08-13-2002 | 09:12 PM
1991rsblue's Avatar
lets see a pic. did you use led's or just regular lights??
Old 08-14-2002 | 09:33 AM
PopaPork's Avatar
I used 10,000 mch blue leds with a 470 resistor. I gotta figure out why my speedo lights dont work no more though before I can get a picture..
Old 08-14-2002 | 11:28 AM
IROCME's Avatar
Car: 1986 IROCZ
Engine: LB9....rebuilding coming soon
Transmission: rebuilt 700R4
I got red lights in mine
Old 08-14-2002 | 03:08 PM
1991rsblue's Avatar
i was told if you put more than 7 in parrelell then you need a 50 ohm resister. how many led's did you use? did you tie all them in together or seperately?
Old 08-14-2002 | 08:19 PM
PopaPork's Avatar
well I got some major problems. The way I made mine were LED with a 470 ohm resistor then attached to the light bulb socket. Well on my way home from work today I noticed something burning smelled like rotting grass. Well I looked down and smoke was coming out of my dash..UT OH. I dont know whut the F happened
Old 08-14-2002 | 08:48 PM
1991rsblue's Avatar
welp i'm ok with electronics but placement opf the led's was my problem. i didn't have enough area's bright enough. the way i hooked everything up was this way, maybe it could help you. i used the formula in the tech article for these things. i hooked up 7 led's in parelell and used a 33 and 10 ohm resister tied into each other. and to the lights and to power. then grounded the other end of the 7 led's. it works great! and burning, atleats not for the past 3 months. i just need to find out where i should place the led's on my circuit board i made for it. good luck and fires arent good!!!! in case you forgot. if you have anymore questions pm me.
fonzie85
08-13-2015 12:50 PM
tnrednneck
08-13-2015 09:57 AM
ChevyZ71
08-13-2015 08:30 AM
Omega
08-10-2015 01:46 PM
