door locks
Old 08-12-2002 | 04:35 PM
demon138's Avatar
Car: 89 Pontiac GTA Trans Am
Engine: T.P.I. 383 Stroker
Transmission: Monster 700R4
door locks
my power door locks dont completely lock is there a way to fix this or do i have to buy new solenoids for the locks?
Old 08-12-2002 | 04:56 PM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
If you've removed the door panel and greased everything with white lithium grease, and verified nothing is binding, then yes, you'll probably end up replaceing the solenoids.
Old 08-13-2002 | 12:43 AM
zer0321's Avatar
I've had that problem before:
turns out that the metal rod that you use to manually lock/unlock the doors was a little bent and needed to be straightened out....easy 15min fix.....
13sec83trans
Carburetors
22
11-28-2015 10:26 PM
my86bird
10-23-2015 01:20 PM
83 Crossfire TA
09-08-2015 01:06 PM
84 TA NV
09-06-2015 09:02 PM
SG91camaro
09-05-2015 11:27 PM
