Tire size
Tire size
I just got some cragar ss 15's and I was wondering what size tires would keep them the same Height as stock?
255/60/15
255/65/15
255/70/15
The 60's correct?
Nate
255/60/15
255/65/15
255/70/15
The 60's correct?
Nate
Hi I'm new here and I'm getting a 86 Trans am today. It currently has the firebird alum rims on it but there's a guy that i know that is selling a set of 15' cragar rims. the exact sizes are 2-15x10, 2-15x8. I think these rims will look really aggressive once i put them on. I would also like to know what tire sizes i should get.
thanks.
thanks.
Ok Here's how you figure it. The first number is section width in mm (255 mm) the second number is the aspect ratio, which is basically the percentage of the section with and describes the sidewall height ( .7 x 255 = 178.5) The last number is wheel diameter in inches ( 15 ). So the standard tire wheel size is 245 50 16. 245 x .5 x 2 (sidewall twice) = 245. There are 25.4 mm in one inch, so 245/ 25.4 = 9.65 inches. 9.65 + 16 = 25.65 Now we work backwards
25.65 - 15 = 10.65
10.65 * 25.4 = 270.51
270.51 / 2 = 135.255
135.255 / 255 = .533
135.255 / 245 = .552
135.255 / 270 = .500
135.255 / 225 = .600
So somewhere between a 50 and 60 series 255 section width mounted on a 15 in wheel. So, which way do you go? A 60 series will make the car think it is running slower than actual, so you'll get more tickets. A 50 series will make the car think it's going faster, and you also get a little extra torque mult. If you get a 270/50/R15 you keep the same height, or a 225/60/R15 (stock specs for a 15 in. wheel).
25.65 - 15 = 10.65
hey atomonkey, if you happen to check this post again,
could you double check my math here--
I saw a set of tires on a thirdgen that I really liked height/aspect wise. The size was a 245/45R17. I would like to run 295's, so if I go with a 17 tire, I'll need about a 295/40R17, and it would be just a hair taller. That seems a little odd, but here's my math.
245 * .45 * 2 = 220.5 total sidewall height
220.5 / 2 / 295 = .37, so either a 35 or 40 series, right?
If anybody else wants to explain this better or agree, I'd sure appreciate it. I'm trying to find a good mix between performance and avoiding the thin walled rice look. Thanks.
Car: 88 ramair grey camaro
Engine: 388 stroker
Transmission: th350
AUhhh i have the Old cragger SS on my babey they are the deaper dish and i will tell you what... THEY SUCK... i cant go no wider than 205 60 15 on the front becuase it will rub if i do down and hight i can go wider BUT that just looks stupid...
I got some Big meat on the back tho and well its good for racing in stright lines i guess i blan on buying Elite Barb rims 16 one the opisite dish from what mine are and stuffing 275 55 16 on there
Car: 1986 Firebird
Engine: 2.8 V6
More on "torq mult"
Shorter tire/wheel height? Faster 0-60, smaller top speed, more rpm's in gear. Speedometer reads faster than actual speed- ex, you're doing 60 mph, speedo says 65.
Taller tire/wheel height? Slower 0-60, faster top speed, less RPM's in gear. Speedometer is slower than actual speed- ex, you're doing 60 mph, speedo says 55... bad for speeding tickets!
or just go here
http://www.eunos.com/tirecalc/
it will show you a comperision pic of the 2 sizes of tires, comperisian data, and tell you how much you speedo will be off with diff size tires.
By using this I found out my new 17" ZR1 wheels and tires will couse my speedo to read 5 mph higher than the car is really going.
255/60/15 is amost the same as stock 225/60/16
Hotrodboba400
12-10-2019 07:07 PM
TheTraut88
09-07-2015 05:22 PM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
