Tripple gauge pics.
1 Post
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Tripple gauge pics.
Hi..
Finally I got it, tripple A-pillar pod for my GTA -89 .......
What do you think?
/N.
What do you think?
/N.
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Looks good
Looks good, I am adventually going to buy one.
oh yeah:
What do u all have to do to get the gauges to work???
I have the dummy gauge cluster so I need:
Coolant Tempature Gauge,
Oil Preasured Gauge,
Volt Gauge,
Volt Gauge,
1 Post
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Check out www.jegs.com part.nbr 12203...........
Car: 1986 Firebird
Engine: 2.8 V6
Mike, first, you remove the stock "idiot light" switches from the engine. They're called switches because that's all they do, switch on or off, depending on the engine's condition. Example, no oil pressure = the oil pressure switch turns on, and lights up the oil pressure light. (A dashboard with real gauges will use "senders" instead of switches.)
Then you connect the new gauges to where the old switches were, in the engine. If you use mechanical gauges, you'll actually lead physical tubing to the engine. Problem is, some holes (like for a temp sensor) will have to be large. A benefit of electric gauges is that they use stock-style senders. You screw them into the engine, and run a single wire from the sender to the gauge; as opposed to messing with tubing.
A volt gauge basically goes to a voltage source that comes "on" when you turn the car on.... kind of like the radio. And of course there's no mechanical gauge for that!
I have an oil pressure gauge and water temp gauge, both by Summit, 2 1/16th inch, in a dual gauge pod. I like the triple, though! I was originally going to just add air/fuel, but now I also want to add trans temp. Problem is, I don't know where to put the damn things.
Re: Tripple gauge pics.
Originally posted by gta324
What do you think?
What do you think?
But it still looks good.
1 Post
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
ahhhh, it says only for a hard top. Thats beat.
I used a bit of my old A-pillar and if you dont know it you'll never se it......................Looks good.................
And for the Boost......dont have it yet, but the engine is prepared for it...........needs new transmissionfirst and some major ECM /DFI work.................
Car: 1986 Firebird
Engine: 2.8 V6
Re: Re: Tripple gauge pics.
Originally posted by Matt427
But when I consider all those Civics', Neon's, and Focus' that are running around with A-pillar gauge pods that I think; I would never do that to my car. I know it sounds stupid, but look at it this way. If I liked wearing a green baseball cap, and suddenly, by coincidence, all of the numskull teenage punks started wearing green baseball caps, I'd burn mine so as to not be associated with them.
Location: Ocean State, lil Rhody, the biggest littlest state in the union, Rhode Island
Car: 1988 GTA Black/Gray
Engine: Blown 355
DAMN, I wish I found a triple pod before I installed my double. Mine too is from Autometer, but I saw no listing for a triple. I need a place for an A/F gauge and don't know where to put it.
Re: Re: Re: Tripple gauge pics.
Originally posted by TomP
I've had my gauge pod since '96, before the rice explosion. They're all copying me!
You know that, and now I know that, but they don't know that. Those knuckleheads probably think A-pillar pods were invented for them, so they think that you are copying them. But that wasn't really my point. I wouldn't want anyone to see my car and assume I'm in the same category as these kids with unnecessary gauges, lights, fire extinguishers, etc.
But, in the end, I'm sure you don't care what I, or anyone else, thinks about your car...as it should be.
Car: 1986 Firebird
Engine: 2.8 V6
True, never thought of that. Heh, next time I talk with a *****, and they mention the gauges, I'll be sure to say "had them since 96, before the import scene ever happened." I'll say that last part with a sneer.
And yeah I love the fire extinguishers mounted on the windshield... not to mention how hot the windshield gets!
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
Originally posted by xpndbl3
i'm assuming that this is for 2 1/16" guages right? because i have 2 5/8" gauges. SO i guess i'm out of luck right now
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Originally posted by Hg
gta324: What series gauges are those? Are they the phantoms?
Car: 2000 Corvette FRC
Transmission: M6
Dual guage pods for a t-top = 52.99
Triple guage pods for a hard top = 52.99 ... WTF
The duals that summit sells are adheasive ones for 24.99. Do the ones that jegs carries replace the whole pillar?
Car: '87 Z
Engine: 355 in the works
Oh, just thought of a question. What did you have to do to modify them for the T-tops? How are they different from a hardtop one anyway? Thanks.
The triple one I have goes over the entire stock pillar.
I am not sure of the part number at the moment, but when I ordered it, I did it online and the part was listed when I did a search.
Originally posted by igotslicksNchix
...apperently you've never driven an 86 regal...
you gotta be cool to get a regal, so long as it doesn't catch on fire, and cats don't climb in your belts in the morning, what a freakin mess
and how do you modify the cheaper hard top version to fit t top cars so i don't have to pay extra $$$?????
Location: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I love my 3 pod A pillar guage holder from Lo-Tek(sorry out of business) with the Autometer guages and I don't give a damn about the ricers. If they don't like it let's race.
