for those who wanted to see the 4th gen gauges working in my iroc
#51
u r sofa king we tah did, where did you get that wire color/description from and what year 3rd gen is it for. It does not match up with my plugs on my 91z28. aslo, you have white listed twice. how do yo uknow what white wire is what. same goes for other wires with the same color.
#52
Car: 90 irocz
Engine: 350tip
Originally posted by BOTTLEDZr28
I have in my hand the connector that plugs into the 4th gen cluster. I was matching up the colors to the diagram listed above and for some reason, some things dont match up. first, is there going to be a lot of wires left unconnected on the 4th gen plug, second, red wire on the 3rd gen dash needs to be splied into the pink/black wire. I do not have a pink/black wire. This would be a pink wire with a black stripe right.what have you guys come up with that did this already. also what about the other switches like the headlights and heater. These are the wires I have
4th gen cluster plug:
pink
pink
brown/white stripe
dk green
tan
tan/white stripe
grey
grey
dk blue
dk blue
lt green
red
brown
green/white strip
yellow
white
white(slightly bigger gauge)
purple/white stripe
lt blue
lt green(bigger gauge)
black(bigger gauge)
brown(bigger gauge)
black/white stripe
purple
orange(bigger gauge)
yellow/black stripe
pink
pink
brown/white stripe
dk green
tan
tan/white stripe
grey
grey
dk blue
dk blue
lt green
red
brown
green/white strip
yellow
white
purple/white stripe
lt blue
black(bigger gauge)
brown(bigger gauge)
black/white stripe
purple
yellow/black stripe
#53
The gauges cluster is out of a 94 camaro V6. At least thats the year written on the windsield of the car at the boneyard.Can you get me a wiring diapgram thingy for a 94 and 95 and also my 91? I have been trying to peice togehter the wiring and there are a few spots that got me stuck. I know there will be wires not used on the 4th gen connector but should ALL the wires on all the 3rd gen connectors still be used on the 4th gen connectors. I know GM had wires run in the car that never did anything as they where for other year cars and options. Have you figured out a way to run the cable for the heater controls to open different vents? and what about the vacuum lines. Im sure I will figure it out but if your furthure then me then please give the secrets to help me along
#54
Re: Re: someone needs to make this a tech article
Originally posted by CustomX
Question: Will this work on the 97-up guage cluster wiring harness as well?
97 prior clusters is desireable , because all the signals to the guages in the LT cars are the same as 90-92 cars . Cant speak about the 89-earlier ....I havent worked on those . You may possibly have issues with the speedo reading correctly as well , I doubt it though . If your car is auto , I know the 90-92's used a 40 pulse signal , like the 4th gens . All the idot lights and turn signal lights and such should all work correctly once all the 3rd gens cluster wires are put in the right places in the 4th gen connector
Good luck
To bad you werent swapping in an LT or LS engine . the dash wiring would actually be ALOT easier on the mind , hehe
Derek
95 Trans Am vert | 98 Ram air front end
MTI stg 3 LT4 heads , cc306 , th350/4500 stall , LT's , True duals w/ X-pipe , Wolfe cage
#56
Car: 90 irocz
Engine: 350tip
If im not mistaken, dont the 90-92 tpi cars uses a 4000 pulse per mile? That would be why i ordered a speedo interface box form dakota digital.
As for the tach......if thats correct i should be able to use a interface box as well to recalibrate the signal would i not?
Srry bottled, I can only dig up 98-newer wiring diagrams/service manuals off gm's tech site. didnt realize that until i went to dig up a diagram for ya.
#57
Custon X, thats for trying. I have a book for the 4the gen cars. I started to connect the headlight switches today. I spent from 10am to 5pm and got nothing done. Im not the best wiring diagram reading. I do have the switch working but there are small problems like the foglight switch doesnt light up when there on, the light in the headlight switch comes on when I open the doors but doesnt come on when I turn the lights on. I cannot figure out the dimmer switch wires. I was gonna give it a break and try the heater controls but I don't want a mess yet and I need my heat.
Has anyone got the headlight switch to work right. I dont remember if the 4th gen cars had an audible tone if you left the lights on or the keys in the ign. my 91 does and i get the feeling I will loose all that with this new dash. Not a biggie though. I just want the headlights hooked up the correct way. if anyone can give me some help to get me along that would be great. I will try again tomorow.
#58
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
I haven't seen it asked or explained in any of the 4th gen dash posts.
BUT what are you planning/doing about the trim piece on top of the dash where "our" (thirdgen) dash pads are normaly?.... The 4th gen dash is deeper than the thirdgen.
Also for whoever asked about the cluster wiring diagram for a 95 Z there was one posted in the LT1 section on camaroz28.com not to long ago.
#59
ok I got the headlight switch hooked up today. It does not work like the old one though. When I turn my high beams on, the fog lights and low beams stay on too. I like it that way but not sure why its like this. Here is how I have my wires hooked up. BTW, this is a 91z28 with a 95z28 dash:
3rd gen 4th gen
HEADLIGHT SWITCH HEADLIGHT SWITCH
red------------------------12 volts hot---------------red
black-----------------------ground--------------------black
yellow------------------dimmer switch(?)-----------yellow
orange-----------------fuse block--------------------orange
dk green--------------NOT USED
white---------------------to both white wires on dimmer switch
brown--------------------brown on headlight switch
brown on fog light switch
grey on fog light switch
brown on dimmer switch
3rd gen 4th gen
FOG LIGHT SWITCH
yellow-----------------not used
purple-------------------------------------------------yellow
black---------------------------------------------------black
grey----------------------------------------------------lt green and grey
DIMMER SWITCH
not used--------------dk green
white on headlight switch------------------- white
white on headlight switch------------------white
ground----------------- black
brown on headlight switch---------brown
someone please check this for errors on there swap. It is working for me but here is the small problems:
I have no dimming, all the dimmer switch does is turn dome light on
the buzzer will not shut off unless i put my seatbelt on
the light for the heater controls does not turn on after turning the lights on
I do not have a cluster yet so checking that will have to wait.
3rd gen 4th gen
3rd gen 4th gen
FOG LIGHT SWITCH
DIMMER SWITCH
#62
Car: 90 irocz
Engine: 350tip
thats my plan since its all in one. Shouldnt be too bad since thier shoudl be hole for the 4th gen swtich to poke though to attach to the ****.
#64
Custom X, I put a few descriptions of the wires list you put in a post. They are very similar to my 95 cluster:
Dark green ------------------------------------temp gauge
Dark Green/whitestripe ---------------------VSS
thin light green --------------------------------ABS fail(not used)
Thick light green------------------------------ high beams indicator
thick black--------------------------------------ground
black/white stripe ----------------------------ground
red -----------------------------------------------check gauges(not used)
2x pink ------------------------------------------hot in run,hot in run
2x blue -----------------------------------------low trac,RH turn signals
blue/white stripe ------------------------------unknown
light blue/white stripe-------------------------unknown
orange-------------------------------------------12V (not used)
2x white-----------------------------------------tach,skip shift(not used)
thick brown--------------------------------------air bag light
thin brown----------------------------------------low oil light(not used)
2x thin brown/white stripe --------------------SES light,unknown
light tan -------------------------------------------oil pressure gauge
light tan/whitestripe-----------------------------brake light switch
Yellow/Black stripe-------------------------low coolant light(not used
2x purple/white stripe-------------------TCSlight(not used),unknown
Does the 2x mean 2 wires of that same color? If so then I put both potential functions.Comparing your colors to mine, and what is listed, there is no wire for the fuel gauge. my color for it is purple. this may be the second ppl wire you have. There is no LH turn sig., mine was lt blue. my seatbelt light is yellow, all my cluster lights are grey wires.
There will be wires left over obviously. I am waiting on my cluster to come in so don't quote me on these findings. Let me know what you come up with because some wires on the 4th gen cluster have the same color as others so I will have to test them with the 3rd gen wire to see if that function or gauge works.
#65
Car: 90 irocz
Engine: 350tip
Yes the 2x were for the actual number of wires with that color.
As for the actual uses: I got this from Gm for the 98 specific cluster.........im not positive it applies to earlier models........
https://www.thirdgen.org/techbb2/sho...hreadid=152340
#69
Car: Check The Sig
2 things before i go to bed.... no on the 2nd get thing... and nick, car is lookin super sexy... oh.. nick, is ur site down too?... chaos has been down for like a week now... this is some bull ish
#70
Car: 90 irocz
Engine: 350tip
9192camaro
16
02-03-2019 12:21 AM
mustangman65_79
08-11-2015 03:17 PM
