nose reinforcement panels
sometime ago i saw these panels you could install behind the plastic nose to keep them from dipping in and giving a deformed reflection....does anyone know where to find them?
Stock GM spoilers have a black plastic molded piece that is pop-riveted behind to support it. Aftermarket ones don't have it, but have the holes that would be used to attach one (I know because I just did). It takes a large dia head Pop-rivet (.625") 3/16" body for .376-.500 material grip range. I bought 18-8 ss rivets, but you don't have to. Because it was ss it was a b*tch to suck up the rivet and get it to break the stem using a hand operated pop-rivet gun. McMaster-carr stocks the rivets in aluminum w/al. mandrel #97447A075 or al w/steel mandrel #97517A075. http://www.mcmaster.com/
I haven't installed the spoiler yet, so I could snap some digital pictures if you need.
Good luck, Lon.
Good luck, Lon.
ront bumper cover panel indentations
i was talking about the nose panel if you are looking at the front of the car, the pointed nose panel just below the hood in the center and to both sides of the emblem...that is where it dips in...i have seen countless Camaros with the same problem and saw something on the web about reinforcment panels you could put on the back side to prevent this from happening
any ideas guys?
any ideas guys?
wow!!!
I hope someone has info mine is "sagged"
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
You might have to make something, its been a problem with GM's rubber bumper panels for years, Ever seen a 75-82 Corvette, they have the same problem.. Fortunately for them they have fiberglass parts available...
You might consider taking some sort of foam and making it fit behind the front facia to support it, to make it straight. Unfortunately I think after it begins to sag, it also stretches, so getting it "perfect" might be a challenge...
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
All thirdgens that I have seen do this. Tomorrow morning, im picking up an 85 T/A front bumper from the junk yard, and I'm gonna line the entire inside of it with fiberglass to reinforce it so it wont sag. If it turns out well, I'll write a tech article.
Originally posted by Ward
...I'm gonna line the entire inside of it with fiberglass to reinforce it so it wont sag. ...
Car: '86 Trans Am
Transmission: TH700R-4
Axle/Gears: 10 bolt 3.73
I'm fiberglassing mine right as we speak and it is a hell of alot more rigid than stock.
I also put metal reinfornment on top of the fiberglass.
BumpaD yours isnt even that bad. The nose that was on my car, before my accident, was perfect. The new one the shop put on sags about as much as yours does and like I said it isnt that bad. Iv'e seen SO much worse o_o If it gets worse, just replace it.
formula00ra
Interior Parts Wanted
09-28-2015 11:50 AM
