How to remove fade strip?
Old 06-18-2002 | 08:43 AM
Cool Runner's Avatar
Car: 86 Trans Am WS6
How do you remove the fade strip that is just above the gfx on 85-90 TA's?
Would adhesive remover help or is it useless on those vinyl strips?
I'm trying to remove it while saving the paint underneath, so it that possible.
Old 06-18-2002 | 09:00 AM
Azure's Avatar
From: "No one cares if you're in before the lock!" - Best quote ever.
I removed the striping on my bird a little while ago...I can't recall if the T/A material is a bit different, but oh well. You have to be real patient, but I took an exacto knife blade and sloooowwwwwwwly chiseled (sounds like a bad word to use for paint!) the striping off. The paint underneath was fine, (looked brand new, so that made for some waxing/buffing), but I had to take Goof Off adhesive remover to the glue the viynl left over. Looked much better after I was done, sorry I don't have any pics.
Old 06-18-2002 | 09:38 AM
<----is very dangerous with exacto knife
Well if that Goof Off stuff didn't hurt your paint then I'll try that first before taking the knife to my TA.
Old 06-18-2002 | 10:54 AM
ramrod85's Avatar
Car: 85 Z28
Engine: 350/ 290hp EZ-EFI
Axle/Gears: 3.08 posi
GooOff and elbow grease, may be a heat gun(use catiously)
Old 06-18-2002 | 12:58 PM
1986redbird's Avatar
if you can get one edge started you can spray some WD-40 on the adhesive and it will disolve it pretty quickly, that stuff will remove most label type of adhesives really good.
Old 06-18-2002 | 01:45 PM
86IROCZ's Avatar
3M eraser wheel and a drill!! Get one at the paint shop.
GeneralIesrussi
Carburetors
06-20-2024 08:21 PM
MY87LT
Aftermarket Product Review
06-07-2016 10:47 PM
fasteddi
09-10-2015 10:32 AM
Amillionoh7
09-06-2015 12:44 AM
Vassago
Convertibles
09-04-2015 10:37 PM
Quick Reply: How to remove fade strip?
