what holds this piece of ground effect on??
Old 06-16-2002 | 04:36 PM
Camarokid01's Avatar
ok I have a camaro berlinetta/sport coupe, I just had iroc ground effects put on but am missing the bolts or whatever that hold the front nose ground effect on to the fenders, if you dont know what I mean it is the front ground effect where is wraps around to the bottom of the fenders. it looks like plastic rivets hold it on but I am not sure, there is 3 different holes for bolts/rivets to go through, if someone could look under their car that would be a big help.
Thanks in advance everyone, sorry for such a long post
Old 06-16-2002 | 04:55 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
It s a bracket that slides into the GFX, and it has pressed in studs. The studs go through the fender holes, and are tightened down with a nut on the other side. You can order the brackets new from GM for ~20 bucks...
Eric
3rdgenparts
Exterior Parts for Sale
26
04-07-2016 12:21 PM
Thomas
21
10-07-2015 06:33 PM
Thomas
10-03-2015 06:34 PM
mikey8494
08-22-2015 08:57 PM
92firebirdchris
08-14-2015 12:56 PM
Quick Reply: what holds this piece of ground effect on??
