Can This Be Repaired?
Old 06-13-2002 | 04:33 PM
TimRS's Avatar
Car: 91 RS (Sold 90 IROC) 07 Avalanche
Engine: RS 305 TBI
Transmission: RS 700R4
This is the passenger side door where the lock cylinder goes. It's on my 5-speed...the previous owner says it was from an attempted break in. I've used the Eastwood lock reforming tool but not with much luck. Is there an easier way or is it even worth trying?
Old 06-13-2002 | 05:14 PM
1987fbd's Avatar
Dude that is ugly. You are better off getting another door. It can be done but will never look the same and if it did it wouldn't be as strong. Unless of course you are really attatched to that door...then there is always welding.
save your money buy another door.
Old 06-13-2002 | 06:15 PM
2vmodular's Avatar
could weld the hole shut and retrofit remote keyless entry. if you don't currently have power door locks, you'll need to install a couple of aftermarket door lock actuators.
Old 06-13-2002 | 06:36 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Or you could have a bodyshop fix it for you. You might be able to get the "lock area" around the lock from a dented door in a junkyard for a good price. Then the body shop could just weld the new piece in. Or, maybe they'd rather weld the tears in the existing metal shut- can't hurt to ask them what they'd want.
Old 06-13-2002 | 07:48 PM
1987fbd's Avatar
In other words what I was saying. If you do have a body shop weld a peice on for you the cost will be ugly. Like as much as a nice junkyard door.
Old 06-14-2002 | 10:00 AM
Steve89GTA's Avatar
Same thing happened to my 89. THe body shop cut the piece out and welded in a new piece. It looks flawless dude. It can be fixed.
Jorlain
Exterior Parts Wanted
06-30-2017 12:04 AM
SRKLEGIN
09-30-2015 08:19 PM
Aaronv808
Members Firebirds
09-30-2015 01:55 PM
HoosierinWA
Members Camaros
09-29-2015 01:43 PM
ironbmt
09-27-2015 07:00 AM
Quick Reply: Can This Be Repaired?
